WTF: whats wrong w/ my car!!
Old Sep 25, 2001 | 06:50 PM
clean's Avatar
New User
Default WTF: whats wrong w/ my car!!
i have had a CEL on since i put my turbo on. i used the blue box that came w/ the greddy kti and put it on my 6th gen like everyone else w/ 6th gens do. so i thought it was the box so when my FMU, missing link bypass valve, and fuel pump came i went to put them on. after i put the check valve and FMU on i wanted to start the car and see whats up, sweet no CEL hit the gas and the car stalls!!!!!!!!WTF. WHATS WRONG HERE also how do i relieve the fuel to put the pump in i need to know where the electrical connector is on my 97
Old Sep 25, 2001 | 07:32 PM
VaporTrail's Avatar
New User
Default Re: WTF: whats wrong w/ my car!! (clean)
Your check valve appears to not be working. Try adding some more. The reason your car is stalling is b/c the MAP sensor is seeing boost.
Old Sep 25, 2001 | 07:55 PM
bigTom's Avatar
Default Re: WTF: whats wrong w/ my car!! (VaporTrail)
he isnt under boost according to his post though... just revs the motor... am i correct?
Old Sep 26, 2001 | 04:53 AM
newsense's Avatar
New User
Default Re: WTF: whats wrong w/ my car!! (ek9t)
doent matter if its boosting or not.... let me guess.... it will start and idle just fine.... as soon as you rev it will bog a little, then shut off..... i had same problem..... its probably the o ring for the map sensor.... at least that was my problem... check that
Old Sep 26, 2001 | 11:45 AM
clean's Avatar
New User
Default Re: WTF: whats wrong w/ my car!! (newsense)
dude yah the o ring!!! it came w/ 2 i i didnt know if i had to replace the roiginal. so i left off the one that came w/ it. i tried putting it onw/ the stock oring, then w/ replaceing the stock ring. so how does it go? i dont want to take it off to much more cause the srew heads are starting to get stripped cause i thought it had to be on tight. help!!
Old Sep 27, 2001 | 02:00 PM
cccya's Avatar
have u tried to put both o-rings on yet, and see if you can get it as tight as you can? make sure there is no leaking, and u should be good, right???...
Old Sep 28, 2001 | 04:08 AM
clean's Avatar
New User
Default Re: WTF: whats wrong w/ my car!! (cccya)
Adam , i already tried that and then i tried putting the propanetorch on it while it was running yo see if it would idle higher and it didn't. i know it's the MAP sensor, but does anyone know if the check valve itself could be defective? i bought it from importparts.com for 59.99.
Old Sep 28, 2001 | 04:22 AM
newsense's Avatar
New User
will the car start without the check valve on?..... try it with just the map sensor on...
Old Sep 28, 2001 | 04:28 AM
clean's Avatar
New User
yah if i put the map sensor on and tighten it down i'm sure it will work fine , but i cant drive around like that, it will read boost and the car will stop, thats what the check valve is for. i also tried it w/o anything,, why? i dont know that was dumb, cause basically fuel poored out my exhasut sweet right? no
Old Sep 28, 2001 | 10:58 AM
Accord1999's Avatar
New User
If your check valve is the one that you buy at your local parts store, try to turn it around. The check valve have a direction of the air flow. It happen to me and symtoms are like yours.
Old Sep 28, 2001 | 06:12 PM
clean's Avatar
New User
Default Re: WTF: whats wrong w/ my car!! (Accord1999)
i'll try but i think i'll have the same effect, how would i know if i broke the MAP itself? also i have the stock and the check valve o-ring on top of each other on the bottom cause from the directions that is what it sounds like i gotta do
[Modified by clean, 3:14 AM 9/29/2001]
Old Sep 29, 2001 | 06:26 PM
clean's Avatar
New User
how bout this, when i put the valve on i still had the blue box from the greddy kit on, i started the car to see if it worked the same time the box was on. the box somehow tricks the MAP into not seeing pressure so w/ the check valve maybe i fried something? i don't know. i think i might even try putting the blue box back on and take off the check valve and the FMU. anyone else?
willie0315
Jul 2, 2009 10:29 AM
KrispyKreme
Jun 17, 2005 12:03 AM
urbansi
Jun 8, 2005 05:39 PM
turbod16y8
Aug 21, 2002 11:50 AM
not so civic
Aug 29, 2001 01:19 PM
