WTF I need help guyz
Old May 3, 2004 | 08:12 PM
91glassycrx's Avatar
Default WTF I need help guyz
I got a used T25 turbo kit anf it ran fine for like 3 days then the turbo seals went out. I just got a brand new T25 and got it hooked up. The car smokes like ****. I thought mayeb i hook the oil feed up wrong and changed the but it was wrong and it poured oil all in my exhaust. So i'm going to put them back right tomorrow . The car hasn't been driven since the new turbo went on. Could I have too much oil pressure I have about 30-50 psi at idle and when i'm on it its at 75-90 psi. When I start it cold its at abuot 80 psi help me please guyz this is my daily driver and I need to get it back on the road. Does the oil return have to face straight down. Let me nkow guyz lata
Old May 3, 2004 | 08:20 PM
sporkcrx's Avatar
Default Re: WTF I need help guyz (91glassycrx)
A bad oil return line can cause oil backing up which will get past the seals. Any pics of the return line?
Old May 3, 2004 | 08:26 PM
Default Re: WTF I need help guyz (sporkcrx)
its 5/16 hose man does it have to drain straight down
Old May 3, 2004 | 08:32 PM
Hoosier Daddy's Avatar
Should be as straight as possible. What does it look like?
Old May 3, 2004 | 08:41 PM
Default Re: WTF I need help guyz (Hoosier Daddy)
the way i had to mount the turbo its staright back but kinda up a little. It faces u when u open the hood. I tried to rotate the center section do the oil feed is straight up but the compressor outlet hits the manifold . Can i rotate just the center and leave the exhaust side and the compressor side at the same place so the wastegate still mounts and works fine
Old May 3, 2004 | 09:25 PM
98gsrTEG's Avatar
you can not have the oil retun go up at any point. you can not have it kink either. if you have a dip in the line it could cause oil backpressure in the line and cause the seals to blow in the trubo
DX_JDM_HATCH
Sep 17, 2013 02:39 PM
EG95D15VTEC
Jul 5, 2007 01:30 PM
gtcali
Nov 19, 2004 06:43 AM
Blkteg97
Nov 16, 2004 08:04 AM
filetofit
Sep 5, 2002 09:26 PM
