WTF fried 2 ecus(q31) trying to run neptune. what am i doing wrong? pics inside
i fried 2 ecus tonight, same spot. what am i doing wrong, short to ground somewhere? both times it fried q31. when i put the second ecu in, all i did was plug it in and turned the key to one when it started smoking. at the time i had the usb cable, data cable, and 28 pin ribbon connected to the rtp board.
Re: WTF fried 2 ecus(q31) trying to run neptune. what am i doing wrong? pics inside (integra3586)
ummmm is that the IAT piece? i had that problem and the plugs on my IAT and IACV were switched around on the engine harness
edit: nvm, its q21 i burnt out
Re: WTF fried 2 ecus(q31) trying to run neptune. what am i doing wrong? pics inside (eg crunkmonster
is there a diagram somewhere to show which pins on the harness are what? i thought hondata had one, but i cannot find one on there website
hondahookups.com has all the service manuals if thats what ur asking for
i have it on my laptop but not on this comp
yep ur plugs are switched! look in the manual...if u got one...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg crunkmonster »</TD></TR><TR><TD CLASS="quote">ummmm is that the IAT piece? i had that problem and the plugs on my IAT and IACV were switched around on the engine harness
edit: nvm, its q21 i burnt out</TD></TR></TABLE>
no its q31 thats burnt on this
what color are the wires, ill look them up on my laptop
opps blk/blu yel/blk is IAC on engine harness
IAT is grn/blk red/yel
evap purge control solenoid? im pretty sure i disconnected this when i dropped in my new motor
a in the pic, 4th pin over from the right, number 20
thanks, didnt even think to search using the pin number
u need to go out to ur car and look at the engine harness and tell us the colors of the wiring, that will determine if anything is switched around
tdo
07-18-2009 01:07 PM
