coil on plug issue
Old Oct 15, 2013 | 05:20 PM
Lazysk8r2's Avatar
Icon3 coil on plug issue
Iv been having this issue for a couple months now.
I installed Hondata CPR and after a while i finally got it to work.
took the car down the street and as i was taken off it felt like the signal dropped cause it fell on its face for a quick second.
i have been trying to figure out what is causing this problem. I checked all connection.
i replaced my engine harness that was hacked from trying to install it to one that isnt.
I tried 4 different distributors. One even took a **** and left me stranded.
replaced my jumper harness.
made new grounds, cleaned ground surfaces. Tried another CPR box.
replaced spark plugs, went from d17 coils to k20 ones.
It drops randomly sometimes wont do it for awhile.
I havent tried another ecu yet/ cpr harness
Oh and when i datalog you cant tell anything happens from looking at them.
Out of ideas of what it could be. Anyone else experiencing this problem?
Old Oct 15, 2013 | 05:25 PM
ricetastic's Avatar
Default Re: coil on plug issue
i did..then it fixed itself after a retune...
try another ecu man!!
Old Oct 15, 2013 | 06:41 PM
turbociv910's Avatar
try not using that junk
Old Oct 16, 2013 | 07:08 AM
Lazysk8r2's Avatar
what would you recommend to use with hondata then?
Old Oct 16, 2013 | 07:20 AM
Muckman's Avatar
Moderator in Chief
Post on the Hondata forum and one of the engineers will work with you. It could be a number of possible causes.
Old Oct 16, 2013 | 09:47 AM
Lazysk8r2's Avatar
Iv been talking to them since June, but they stopped responding
Old Oct 16, 2013 | 07:17 PM
ricetastic's Avatar
how is it junk?
less issues than an AEM COP setup and about 1/3 the cost.. especially if you want to run more than 15 psi
big cEe
Mar 30, 2020 10:32 AM
danteisme
Engine Management and Tuning
Oct 9, 2016 05:30 PM
obuhmyuh
Oct 2, 2008 10:51 PM
HandleTech
Nov 30, 2006 12:20 AM
turbob16ef
Sep 28, 2005 06:52 PM
