hep with Barometric Pressure Sensor Circuit
if the 'Barometric Pressure Sensor Circuit' cel code is blinking
how do you alleivate the problem? or what can cause the problem?
would he have to take the car to a honda guy or will the local mechanic know how to take care of it?
i know it controls the air/fuel ratio and might cause my motor to run lean or rich but is it in the ecu itself? would i need to replace the ecu to fix it? let me know!
Re: hep with Barometric Pressure Sensor Circuit (otakueric)
Sounds like the MAP sensor. Yes, it will make your car run like ***...
No, it's not in the ECU, it's mounted on either the firewall, or the intake mani/throttle body. It will be a little black rectangle, and will be labeled MAP sensor.
If it goes bad, you must replace it.
Re: (otakueric)
You have both the MAP and BARO sensors. BARO sensor is usually located inside the ECU, thus fixing it means replacing the whole ECU.
Do you have a VAFC or some other fuel controller?
bmoua
04-15-2007 12:24 AM
