wring diagram for vafc hack????
Old Apr 22, 2003 | 06:24 AM
T3T495GSR's Avatar
Default wring diagram for vafc hack????
i got my vafc and 440cc injectors sitting in my room still and would like to install them, are there any shops around here that know how to and tune it? or is there a diagram so i can do it myself?
im in chicago area thanks
Old Apr 22, 2003 | 06:33 AM
mike1114's Avatar
Default Re: wring diagram for vafc hack???? (T3T495GSR)
Hook vafc up per the directions, there is not secret, not wire switching, just hook it up the way the directions say, bore out or force the injectors into the seals, and wire up the resistor box to the injector wiring. Then lean out your idle and what not so you can run the injectors without turbo. If you already have turbo on the car, go to thedropshop.com and there is a how-to on the settings you need to put the vafc at for narrow/wide throttle etc... to be able to run boost.
Old Apr 22, 2003 | 06:44 AM
T3T495GSR's Avatar
Default Re: wring diagram for vafc hack???? (mike1114)
so remove the missing link and fmu adn just hook it up like normal and use the settings from dropshop.com? oh i have rc 440cc and im obd1 so they just slide right in
Old Apr 22, 2003 | 06:50 AM
mike1114's Avatar
yes. You should be good to go.
tur3oDC4
Nov 27, 2004 07:21 AM
Hoodwinked
Oct 24, 2003 05:04 PM
vet_girl
Aug 23, 2003 07:24 PM
M-EJ1
Feb 14, 2003 11:34 PM
1.8T_EG
Sep 16, 2002 12:22 PM
