Wouldn't start
Old Oct 10, 2001 | 05:32 AM
b18b98's Avatar
Default Wouldn't start
wsup fellas...when i turned the key to start the car this morning all i heard was a clicking noise which sounded like it was coming from the left side of the steering wheel and wouldn't start. I stopped, waited a second then tried again and it started with no problem. I was gonna test it out again but i was late for work so i had to leave. Is it because it was cold outside...this never happened before...the car has a lil over 26,000 and its a 98 RS. Any thoughts appreciated...TIA
Old Oct 10, 2001 | 05:42 AM
newsense's Avatar
New User
Default Re: Wouldn't start (b18b98)
could be a number of things..... i had similar problem, it was my ignition coil... start from there....
Old Oct 10, 2001 | 05:23 PM
speedworks's Avatar
99% sure it will be the main relay. if it does not engage properly your fuel pump will not run. this is a common problem on older hondas with high mileage,not saying your car is being a 98 is old
Old Oct 11, 2001 | 05:12 AM
b18b98's Avatar
Default Re: Wouldn't start (speedworks)
thanks both of you...i'll be troubleshooting this asap...
D50boy
Acura TL, RL & ZDX
14
Aug 16, 2007 04:35 AM
HondaKPX
Feb 17, 2005 10:26 AM
blueeg
Aug 29, 2004 07:25 AM
jonoknut
May 7, 2003 08:00 PM
