starting problem
Old May 6, 2003 | 06:44 PM
jonoknut's Avatar
Default starting problem
the past month or two, when i go to start my car, i turn the key and i hear a "err" sound, the same sound it makes right before you start the car up. but its not repatedly when holding the key turned, just one "err" its the same noise that u will hear if u turn your key real quikc as to start it but not let it start. It happens continually sometimes. I will try with "err" repeatedly every time i turn the key, sometimes it will take ten or fiteen trys before it starts up. and when it starts its just fine, runs beautifully. . what could be my problem??
Old May 6, 2003 | 07:17 PM
NeoGSR's Avatar
Default Re: starting problem (jonoknut)
is the "err" your hearing the ABS sound?
but that wouldn't have anything to do with it not starting right away....weird......
explain the "err" in depth......
Old May 6, 2003 | 08:16 PM
TurboedGSR's Avatar
Default Re: starting problem (NeoGSR)
you mean the fuel pump priming?
Old May 6, 2003 | 08:25 PM
FastNFurious
Guest
Posts: n/a
I have a 95 GSR also with about 130k miles. Just recently I believe I have the same problem. The cause of it was the ignition connection solders were getting old and I had to have my mechanic go in there and redo them. I would check that out. It's only going to get worse
Old May 6, 2003 | 08:33 PM
TurboedGSR's Avatar
Default Re: (David555)
if your talking about the key cylinder on the steering column, I also had that problem but the car wouldnt start at all. no dash lights, no pump priming, no clock. I tought it was the main relay (btw i have a new relay if anyone is interested) turned out it wasnt. all i did was take the plastic cover off, unscrew 3 screws and sanded all the contacts with med. grit sandpaper and put it back together. took no more than 15 minutes. and now i have a new relay that honda wouldnt take back
Old May 6, 2003 | 08:55 PM
jonoknut's Avatar
Default Re: (TurboedGSR)
i have full power my battery and everyhitng, all the lights work and dash and all, the "err" is that noise when someone is starting there car that wont start like er er er er er er(and then vroom when it sarts) that noise. . all i hear is er once. . then nothing. .
jon
Old May 6, 2003 | 08:59 PM
Havokmkr's Avatar
Default Re: (jonoknut)
So it's not even turning over. Check all wires, plugs, battery, grounds, starter, battery cables, etc.
Old May 6, 2003 | 09:13 PM
jonoknut's Avatar
Default Re: (Havokmkr)
im thinking it might be my starter, because eveyrhitng else works fine and once it turn sover the engine is fine. . how could i check the starter???
jon
Old May 7, 2003 | 03:50 PM
jonoknut's Avatar
bump
Old May 7, 2003 | 08:00 PM
jonoknut's Avatar
well today it happend elaving school it took about. . 20 ro 25 turns it was bad. . .i need to do sumthin about this. . can onyone offer any suggestions? are spark plugs a possible problem? i would think i would notice a difference driving. . anywho. .any suggestions? thanks
i also need to do someting about my 4" *** hole. i take it too much
jon
Modified by jonoknut at 4:36 PM 5/8/2003
gavingt
Jun 22, 2017 09:28 PM
PyeeK
Mar 8, 2006 10:21 PM
Daguy418
Aug 3, 2005 04:21 PM
HondaKPX
Feb 17, 2005 10:26 AM
RiCE On IcE 2
Nov 30, 2004 12:42 PM
