Would you be able to weld...??
Old Jan 23, 2003 | 09:10 PM
  #26
project dc2's Avatar
Default Re: Would you be able to weld...?? (UberTeg)
is it possigble to mig weld stainless steel and be strong too ???
Old Jan 23, 2003 | 09:12 PM
  #27
dustin's Avatar
You cannot actually weld them together. The metals will not flow together.
It might LOOK welded (Trust me, I've tried for fun). But it will fall apart.
Dustin
Old Jan 23, 2003 | 09:32 PM
  #28
Default Re: Would you be able to weld...?? (dustin)
Dustin
r u reponding to my post or someone elses ?? im confused here ....
Old Jan 23, 2003 | 11:35 PM
  #29
dumbkid's Avatar
Default Re: Would you be able to weld...?? (J. Davis)
what about steel and cast iron?
Cast welds beautifully. It's the single easiest metal to weld, even easier than mild steel. It joins very easily with other steels, and it's half of the puddle rushes over to meet the other more reluctant alloy for trouble free beads.
Unfortunately, cast iron's welds are extremely brittle which is where the "you can't weld cast" myth sprung up. AS LONG AS IT IS NOT A LOAD BEARING WELD then welded cast iron will last forever. As soon as you stress it... it will eventually fail.
so welding a cast dsm BOV flange to my aluminized steel charge pipe should be fine?
Old Jan 23, 2003 | 11:39 PM
  #30
dustin's Avatar
Default Re: Would you be able to weld...?? (dumbkid)
You CAN weld cast iron. Oxyacetylene is your best bet.
What is the BOV cast out of? Aluminum? Steel? Iron? Plastic? Sugar?
Old Jan 23, 2003 | 11:50 PM
  #31
ninesecrx's Avatar
I thought you could weld a bead around the the steel bov flange and then weld a bead around the aluminum pipe and then be able to weld the 2 welds together? Id bet there has to be a way to do it like that?
Old Jan 23, 2003 | 11:55 PM
  #32
dustin's Avatar
Default Re: Would you be able to weld...?? (ninesecrx)
Well the filler is still just going to be steel and aluminum that still don't want to mix
You can weld steel to aluminum with explosion welding but I don't really think that's practical for mounting a BOV flange.
You can't weld them together using conventional methods.
Old Jan 24, 2003 | 09:10 AM
  #33
UberTeg's Avatar
Isnt that brazing, not welding?
Old Jan 24, 2003 | 09:12 AM
  #34
dustin's Avatar
Brazing does not melt either of the metals you are joining together. You only melt the brazing rod and heat the two metals up enough until they bond but do not flow together.
Old Jan 24, 2003 | 11:06 AM
  #35
Joseph Davis's Avatar
I have zero problems with MIG and arc/stick, never tried with oxy/fuel - mainly use that for brazing copper these days. I build some damn fine stills.
Welding the cast BOV to aluminized (steel) pipe is not a problem. Why don't you try to weld a BOV flange to the charge pipe instead, and not mess up the BOV? makes more sense to me.
Old Jan 24, 2003 | 11:28 AM
  #36
ion_four's Avatar
My money is on BigMoose...when he speaks, it's the truth
Personally...the BRASS flange for my PLASTIC BOV is JB Welded onto an ALUMINUM pipe and has been a trooper for the last 6 months at 7-9psi and ambient temperatures ranging from 30-100+º F...so, it has my vote, as well.
Old Jan 24, 2003 | 04:11 PM
  #37
neiloneil03's Avatar
if you weld a cast piece it is best if you actually bake the piece at like 450 degrees in the oven before doing any weld on it
Old Jan 26, 2003 | 11:39 PM
  #38
dumbkid's Avatar
noo i was talking about welding the cast iron BOV flange, not the bov itself heh...
Old Jan 27, 2003 | 02:53 AM
  #39
qwkteg125's Avatar
Default Re: Would you be able to weld...?? (mos)
in zero gravity, and under water its possible. Ive seen the result its crazy looking. Supposedly really strong too, but expect to pay about 5000$ for 1 bead.
Sweet, a bead worth more than my entire vehicle. That'd be one to see.
JBweld should work out ok, but usually the results are not pretty.
it's not the labor that makes this type of welding so expensive; it's the cost of all that damn rocket fuel it takes to get the space shuttle into orbit.
Old Jan 30, 2003 | 02:36 AM
  #40
TurBoXBirD16's Avatar
Default Re: Would you be able to weld...?? (qwkteg125)
ok...
then would i be able to weld the steel flange to a ALUMINIZED pipe??
these pipes: http://www.jcwhitney.com/product.jht...=14721&BQ=jcw2
Old Jan 30, 2003 | 09:43 AM
  #41
BigMoose's Avatar
Default Re: Would you be able to weld...?? (TurBoXBirD16)
Yes, I weld aluminized exhaust pipe all the time with my TIG. The thin aluminum coating just vaporizes.
Regards,
BigMoose
Old Jan 31, 2003 | 02:30 AM
  #42
Default Re: Would you be able to weld...?? (BigMoose)
thank you.!!!
when they say aluminized.. is it made out of steel with a aluminum coating??
thank u bigmoose !!
Old Jan 31, 2003 | 04:15 PM
  #43
BigMoose's Avatar
Yep, big difference between Aluminum Pipe like some nice 6061 Al alloy which cannot be welded to any ferrous metal by conventional means, and aluminized exhaust tubing. The aluminized exhaust tubing just has a thin aluminum coating that forms a thinner layer of Al2O3 (aluminum oxide) that protects the low carbon steel pipe from rust. If you want to make sure what you have is an aluminum coating over steel, check it with a magnet. Steel attracts, and aluminum is not magnetic.
Put the torch to it, any type you prefer, the few microns of aluminum are gone in a flash and you can easily weld steel to steel. Its a lot easier to weld, not to mention more heath safe, than welding galvanized conduit. A tip for those who may need to weld galvanized conduit, I have taken to stripping the zinc by dipping the ends to be welded in muriatic acid, bought at home depot.
Hope this helps some.
Regards,
BigMoose
[Modified by BigMoose, 8:17 PM 1/31/2003]
Old Jan 31, 2003 | 08:28 PM
  #44
Quick 200k Mile Motor's Avatar
BigMoose
ineedhelp
Welding / Fabrication
Aug 1, 2005 05:50 AM
AzntaggeR
Mar 21, 2005 08:55 PM
youngkow
Mar 25, 2003 12:40 PM
pub
Mar 24, 2003 04:01 PM
Snafu-Si
Apr 29, 2002 05:10 PM
