Drag turbo t3/t4 max hp?
Drag t3/t4 E 50 .63 exhast ..
Could this turbo reach into 400hp range??? Or I need to upgrade bigger turbo???
Motor is completely rebuild 2.0L, 9:1cc,. 3''exhaust, hondata, 650cc, 255lph, precision IC 2.25 - 2.5 piping..etc...
Thanks guys...
Thanks guys...
Re: Drag turbo t3/t4 max hp? (Turbo-Honda)
you can't base a trubo on how mauch hp it can produce, rather how much boost it can safely run without surging.
and on that turbo it looks like it would be around 18psi. in my opinion with higher compression and good tuning you could get 400whp out of that
Re: Drag turbo t3/t4 max hp? (rocket256)
the 400 hp on the drag kit was not on the drag turbo, it was on a .78 gerrett turbo. the rest was a drag kit
and again you can not rate a turbo by how much hp it can produce!!!!
I plan on going 400hp max. Could anyone can tell me what psi I run in a drage stage II E 50trim .63 ... I heard it somewhere in the 20psi range.. Was that correct???
Thanks for replies...
B17aTrbo
12-02-2003 11:49 AM
Double 06
07-10-2002 01:35 PM
