WOT Probs
Old Dec 7, 2007 | 08:11 PM
roachsboosted16's Avatar
Default WOT Probs
Well i have a d16y7 with a t3/t4 turbo kit at 6psi, 240cc injectrs (Dsm Peak and Hold), msd ignition, chipped p28, and full exhaust. i just got done installing the injectors, and heres what happpend....i turned the car on and it idled fine, i put it in gear and it cruised fine, but once i stomped (WOT)on it it suddenly lost almost all power, acted like a bad launch (chugging back an forth) except in gear.
any ideas on what the problem could possibly be, ive heard throwing timing, bad plug wires, bad tune,... anything else? anything more logical?
Old Dec 7, 2007 | 08:29 PM
Default Re: WOT Probs (roachsboosted16)
no one ever helps me...
Old Dec 7, 2007 | 08:51 PM
siiiiick my problems are always urgent, but go for the polls instead.lol
Old Dec 8, 2007 | 05:30 AM
londoncivic's Avatar
first of all 240cc injectors...thats not a dsm injector thats just a stock honda size, and i garentee your running your engine lean and thats why its bucking like a ******. could also be your spark plug gap..gap them down a bit
Old Dec 8, 2007 | 05:51 AM
Boostin_GSR's Avatar
Default Re: (londoncivic)
Yea those injectors seem pretty little. I see that your running a chipped ecu, what is your car tuned on and who tuned it?
Old Dec 8, 2007 | 06:04 AM
m R g S r's Avatar
is the car tuned? or you just running a chipped ecu which you think is a correct tune for your motor?
240cc injectors are wayyyyyy too small.......(unless you meant 450cc dsm's, or evo 560's)
sounds like it is a fuel or spark problem (most problems are)
what are the plugs gapped to? what temp plugs are you running?
what kind of msd ignition? just a 6al box or a full distributor, coil, plug wires, box etc etc,
more complete info would help us evaluate your problem.
and don't bump your thread twice within 45 mins....people will purposely not answer you if you do that.
Old Dec 8, 2007 | 06:38 AM
slow96coupe's Avatar
timming could be offf
injectors are too small
its prolly lean as an anorexic chick
Old Dec 8, 2007 | 03:36 PM
Default Re: (slow96coupe)
nope they are 240ccs it was tuned for 240ccs and im only runnin 6 psi max, so they are maxed out but it shudnt be running to lean. msd ignition coil cap rotor and wires, plugs are regular ngk, i remember that the rotor used tom just spark in a sequence, after the conversion it hase a bright orange ring on the outside of the rotor, is that the problem? i probly will go one stage colder, but wude i look for 8s? i dont kno what are in it rite now.
and as to the spark plug gap what should it be?
Old Dec 8, 2007 | 03:40 PM
Default Re: (roachsboosted16)
also i ran the car on 190ccs (stock) on the same setup w/out p28, and it ran alot better, ran lean but no bucking prob. i made the conversion and it started having these problems.
Old Dec 8, 2007 | 05:15 PM
bump
Old Dec 8, 2007 | 06:36 PM
Old Dec 8, 2007 | 06:40 PM
nihad's Avatar
get 390 or 450 dsm and have it tuned or other wise it going to blow up.
Old Dec 8, 2007 | 06:45 PM
Default Re: (nihad)
omg im not worried at the size of the injectors, im only making at most 180hp which these injectors can handle just under 200hp
Old Dec 8, 2007 | 08:03 PM
anyone else have ideas, i like the sparkplugs im gonna chek the gap tomorro
Old Dec 8, 2007 | 10:59 PM
if its not your fuel which i dont know why your running 240s on a boosted setup..its probably spark and as i stated check your gap i doubt its timing.
Old Dec 9, 2007 | 01:19 PM
thank you im replacing for one stage colder.
Old Dec 9, 2007 | 01:25 PM
boosstboy's Avatar
that still won't help if gap is wrong, try the new plugs gapped at .032
roachsboosted16
Dec 11, 2007 05:17 PM
b18cEF9
Aug 2, 2005 05:29 PM
yusoslo
Sep 25, 2004 07:41 PM
acman1
Apr 30, 2003 05:31 AM
MiraiZ
Apr 8, 2002 02:46 PM
