BoosteD16y7 problem
Old Dec 10, 2007 | 06:24 PM
roachsboosted16's Avatar
Default BoosteD16y7 problem
i just got done converting my d16 to obd1, and after i found that once i floored it and revvd to 4k-4500rpms it stopped pulling and stayed at same rpms and bucked back and forth a little. it does not happen when i put half pedal and rev to 7200rpms. it seems like ut happens once i hit boost at WOT. my iacv is not functioning properly due to its a 3wire on an obd1 ecu, but i assume that that couldnt be the problem when in gear. ive posted this problem many times and changed many things tryin to fix this. plz help.
d16y7:
t3/t4 turbo at 6psi, msd ignition coil, cap, wires, full exhaust, chipped p28 on crome, 240ccs dsm peak and hold injectors.
Previous ideas: lean - checked the air/fuel and its perfect, spark plug gap - at .026, losing boost - pressure check and its good, rotor was burning - replaced.
Any other things to try?
Old Dec 10, 2007 | 06:42 PM
Default Re: BoosteD16y7 problem (roachsboosted16)
bump
Old Dec 10, 2007 | 07:48 PM
zcrx2006's Avatar
fuel cut? maybe them 240s are way to small for your setup.....
Old Dec 10, 2007 | 08:12 PM
Speed_1's Avatar
It sounds like your Map sensor is seeing the boost and sending the car into limp mode.
Old Dec 10, 2007 | 08:35 PM
Default Re: BoosteD16y7 problem (zcrx2006)
no the injectors are big enuf
Old Dec 10, 2007 | 08:36 PM
Default Re: (Speed_1)
no i have the missing link
Old Dec 10, 2007 | 09:15 PM
da_dude's Avatar
Why 240cc injectors? That is basically stock y8 injectors. Get some DSM 450cc injector, chip your obd1 ecu and get it tune. You are bogging because you are running lean when it hit full boost.
Old Dec 11, 2007 | 01:45 PM
thomas@LPS's Avatar
Default Re: (da_dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_dude &raquo;</TD></TR><TR><TD CLASS="quote">Why 240cc injectors? That is basically stock y8 injectors. Get some DSM 450cc injector, chip your obd1 ecu and get it tune. You are bogging because you are running lean when it hit full boost. </TD></TR></TABLE> or too rich... why are you running a missing link if you have a chipped obd1 ecu? this would make it nearly impossible to tune unless your using a rising rate fuel pressure regulator. the ecu is not going into boost tables with a missing link.. a little more info on the setup and we may be able to help.
Old Dec 11, 2007 | 02:02 PM
97grnrs's Avatar
fix the obvious problems first. iacv, sometimes stupid problems can cause other non related problems. second, i dont think u should use missing link when u are running a program on the ecu or the ecu will never know what boost u are at and wont compensate fuel or spark. look into it before u blow it up , im not sure which program u are running though
Old Dec 11, 2007 | 02:13 PM
93CX's Avatar
Default Re: BoosteD16y7 problem (97grnrs)
240cc dsm injectors huh?
Old Dec 11, 2007 | 02:47 PM
97grnrs's Avatar
Default Re: BoosteD16y7 problem (93CX)
i know non turbo eclipses came with small injectors. maybe he has them . either way they wont be better than stock
Old Dec 11, 2007 | 02:48 PM
thanx for the missing link advice i will try running w/out it. and 240ccs can hold almost 200hp im not hitting more than 180hp.
Old Dec 11, 2007 | 03:14 PM
93turbo16's Avatar
OK, let me get a couple things straight.
When you say checked your a/f.. do you mean checked it with a wideband or just a normal auto meter a/f gauge??
Also if you have crome, you can disable the IACV code or you can do a wiring trick to the 3-wire sensor that consists of grounding one of the wires.
Old Dec 11, 2007 | 03:45 PM
kyden's Avatar
why do you have a chipped ecu and a missing link?
Old Dec 11, 2007 | 05:17 PM
Default Re: BoosteD16y7 problem (kyden)
thanx for the missing link correction, i was planning on an fmu then heard bad stories...got a chipped ecu and forgot about the missing link, thank you guys i love you! my car is hauling *** like it should be.
roachsboosted16
Jul 8, 2008 07:20 AM
LST2
Jul 10, 2007 06:15 PM
KrazyTurbo
May 28, 2006 08:22 PM
Lei Siew Long
Mar 23, 2004 09:22 AM
