Power Goal
Old Mar 18, 2011 | 05:40 PM
Dsalmeron's Avatar
Default Power Goal
I want to know how much power you guys think my setup can make and still be reliable.
B18b block
JE pistons 9.1 comp
eagle rods
ACL bearing
block guard
OEM built ls head
Mild Port and Polish
Skunk 2 Intake manifold "old version"
Twisted Ram Horn
Garret 60-1
38mm turbonetics WG
880 presicion injectors
255 fuel pump
3" dp
Any info or advice feel free to post would appreciate the help.
Old Mar 18, 2011 | 07:04 PM
92redhatch's Avatar
Default Re: Power Goal
With a good tuner and a reliable setup you shouldn't have and issue with 450whp. Stock sleeve setups can last a while and make good power if you have a good tuner and a nice setup.
Old Mar 18, 2011 | 07:19 PM
AllShowNoGo727's Avatar
i wouldn't go over 400, but i like my motors to last.
Old Mar 19, 2011 | 05:40 AM
Dsalmeron's Avatar
Thanks for the help you guys. I do have stock sleeves so how much would you recommend? With that being said
Old Mar 19, 2011 | 06:00 AM
Schister66's Avatar
Man U FTW
I would set my goal around 425whp. The final say should come down to your tuner
Old Mar 19, 2011 | 08:25 AM
Silva Bullit DC4's Avatar
B18b block
JE pistons 9.1 comp
eagle rods
ACL bearing
block guard
OEM built ls head
Twisted Ram Horn
Garret 60-1
38mm turbonetics WG
255 fuel pump
3" dp
Keep the stock LS 7k RPM redline, discuss it with your tuner to shoot for 400-425 and call it a day man, assuming you're gonna be on pump gas. Your size turbo and injectors are more than enough for that particular goal. Good luck.
In3g_Eg6
Feb 23, 2011 03:11 PM
thatdannyboy
May 10, 2008 02:21 PM
chimmike
Apr 28, 2008 01:02 PM
hatchonarun
Oct 17, 2007 04:42 PM
crazydude75927
Dec 25, 2003 12:53 PM
