Won't boost past 7 psi ?
Old Nov 17, 2002 | 08:27 PM
TheIntegraGuy's Avatar
Default Won't boost past 7 psi ?
What's up everyone. First off, I have a GReddy MBC. If I blow through one side, and feel the other side, I can feel the valve closing/opening as I adjust it so I'm sure it's not the MBC. I have it T'd from the acutator to it's own VAC source to the manifold. I also have the BOV T'd on the same line.
The car runs great and boosts fine. BOV seems to be working properly, but the idle is a little high. 1200-1300 to be exact. I don't know why but when I adjust the MBC, boost doesn't seem to get higher, nor lower. It always stays at 7 psi (.5bar). What could be wrong? VAC leak? My car holds full boost all the way down the line and never drops, so is it possible that it MIGHT be the VAC lines? Please help me out!
-Thank You.
Old Nov 17, 2002 | 10:09 PM
Default Re: Won't boost past 7 psi ? (Esone3)
ttt please.
Old Nov 17, 2002 | 10:44 PM
Boostin Ex's Avatar
I might be wrong understanding you but the blow off valve shouldnt be Teed in with your MBC the boost controler should just be teed inbetween the pressure side of the turbo and the wastegate actuater. Your blow off valve should be teed in off a vaccum source on your intake manifold (Like inbetween your manifold and your fuel regulater)
Old Nov 18, 2002 | 06:18 AM
Default Re: Won't boost past 7 psi ? (Boostin Ex)
I T'd my boost gauge from the FPR...hmmn..I think I'll give it a try..any more suggestions?
Old Nov 18, 2002 | 08:35 AM
Boostin Ex's Avatar
You will be ok with the blow off valve and the boost gauge T,d into that line. I did a F-max kit for a friend and T,d the boost gauge, blow off ,and the additional map sensor in there.
sonne_side
Feb 20, 2009 09:54 PM
anton_
Jun 24, 2008 09:21 AM
98_4drCivic
Sep 6, 2005 09:10 PM
elpiar
Mar 21, 2005 09:09 PM
vtekstorm
Jul 6, 2004 07:06 AM
