JG intake manifold & Drag piping
i have a question for those with the JG manifold & Drag kit
did the piping have to be altered in any way or did it bolt right up
this is for a GSR
any pics you might have will be very helpful along with how much modification if any is needed to make work
TIA
this is for a GSR
TIA
Re: JG intake manifold & Drag piping (APEX i GSR)
I've seen a GSR with the JG Intake Mani and Drag piping. From what I remember, the piping does bolt up, but it's not perfect by any means.
HTH
M
HTH
M
On my si it required cutting of the pipe to make it line up... I don't know if that helps to answer your questions any though
Re: JG intake manifold & Drag piping (B18C4-T)
The throttle body is closer to the front of the car and more toward the pass. side with the jg manifold. You might be able to put it on, it just wouldn't be installed as it was designed. I don't know what kind of clearance issues you will run into.
