wondering about replacement of TB...
Old Dec 19, 2007 | 02:12 AM
B18Sleeper's Avatar
Default wondering about replacement of TB...
Hey guys I just started to disassemble my b16a motor in my si and replace my exhaust/intake valves that where in causing my 3rd cylinder to lose compression. and my car is throwing a code all at the sametime for the TPS sensor. i have heard and read that the tps sensor is supposed to be replaced with the TB. cause they are calibrated to each other, not sure if that is false. but since i am replacing the 4 valves i am going ahead since the motor is apart to replace my valves, cam, and headgasket with all performance part for my turbo build that i am starting shortly. but my question is since i cant go to honda to buy a TPS sensor without the TB with it, would u all just suggest to buy a bigger TB for my turbo build since I will prolly have to replace the TB anyways? or just look around to try and find a TPS for sell? thanks
Old Dec 19, 2007 | 07:33 AM
agrn93ls's Avatar
Default Re: wondering about replacement of TB... (B18Sleeper)
really depends on your goals as far as a bigger tb goes. i would just use the original size. if your gonna be under the 400 ish area. aftermarket tb's are usually more a hassle than they are worth anyway. and omni sells a replacement tps sensor for them, they are a sponsor here check with them.
Old Dec 20, 2007 | 12:38 AM
B18Sleeper's Avatar
Default Re: wondering about replacement of TB... (agrn93ls)
well my goals are over 400 for this car. i want it to be a jdm sleeper, no big flashy stuff on the outside just jdm exterior and interior parts and built turbo motor. but it iwll be a little while before i start the turbo build officially. that is why i wonder if i should change the TB now or later on when i get more into the build. cause i am gettin the turbo kit first before the bottom/top end. thanks for the help i will look up a sponsor for those sensors too thanks.
Old Dec 20, 2007 | 06:49 AM
agrn93ls's Avatar
Don't necessarily just take my word on the TB, i would still look into it. I dont think i would do a bigger TB without an intake. I would try to keep the stock TB if i were you. Im sure that many people have made over 400 with stock TB but i know tons have made a little under on stock TB so it shouldnt be and issue. But there have been many issues with aftermarket TB's binding etc so if you do get one do some research on which to get. The Mustang TB would probably be one of the better options.
Old Dec 20, 2007 | 07:03 AM
rorik's Avatar
I was going to say you could have bought one of my old TBs on egay, but it just sold..
Most of the aftermarket TBs that Iv'e seen don't come with a tps, you have to install your old one. As far as the tps being calibrated for the throttle it's on, I doubt it, I think they're basically just a linear voltage change vs degree change.
Old Dec 20, 2007 | 02:22 PM
mike93eh2's Avatar
uhhhh...
you caliberate the TPS yourself.. if yours has the star head bolts just loosen them and you will notice it moves side to side.. then youll have to match up the volatage for closed and full throttle, dont remember them at the moment, have to look in the book downstairs..
otherwise if yours is riveted on then youll need to drill the heads off them and replace with some bolts.
Old Dec 20, 2007 | 07:58 PM
rorik's Avatar
I guess my post was going off on a different angle, I was just saying that I don't think tps' are different between different honda throttle bodies. Calibrating/adjusting the tps is easy..
Old Dec 20, 2007 | 09:26 PM
mike93eh2's Avatar
Default Re: (rorik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rorik &raquo;</TD></TR><TR><TD CLASS="quote">I guess my post was going off on a different angle, I was just saying that I don't think tps' are different between different honda throttle bodies. Calibrating/adjusting the tps is easy..</TD></TR></TABLE>
all the same..
Old Dec 21, 2007 | 01:33 AM
B18Sleeper's Avatar
Default Re: (mike93eh2)
well right now i have an AEM CAI intake but i was just wondering if all else fails i will just get a new tps sensor somewhere and install it myself. thanks everyone
Old Dec 21, 2007 | 06:17 AM
RACEPAK's Avatar
sup,
the tps setting is 0.45v
just my .02
Old Dec 21, 2007 | 08:26 AM
B18Sleeper's Avatar
Default Re: (RACEPAK)
so is the only place i can get the tps is off a sponsor on here or is there a website? thanks
Old Dec 21, 2007 | 08:52 AM
mike93eh2's Avatar
Default Re: (B18Sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Sleeper &raquo;</TD></TR><TR><TD CLASS="quote">so is the only place i can get the tps is off a sponsor on here or is there a website? thanks </TD></TR></TABLE>
you can get one off any honda throttlebody.. i have a bunch of good extras if you want one cheaper...
or you can get it here..
http://cgi.ebay.com/ebaymotors...wItem
Old Dec 21, 2007 | 09:13 AM
B18Sleeper's Avatar
how cheap?
Old Dec 21, 2007 | 09:19 AM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Sleeper &raquo;</TD></TR><TR><TD CLASS="quote">how cheap? </TD></TR></TABLE>
well theirs is 19 shipped.. ill do 12 shipped. oem honda.
Old Dec 21, 2007 | 09:33 AM
B18Sleeper's Avatar
and its used or new?
Old Dec 21, 2007 | 10:03 AM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Sleeper &raquo;</TD></TR><TR><TD CLASS="quote">and its used or new?</TD></TR></TABLE>
used oem obviously.
Old Dec 21, 2007 | 10:07 AM
B18Sleeper's Avatar
alright let me see when i get my motor back together if it still throws the code and i will hit u up on that
cryingsuns
Mar 20, 2011 01:13 PM
jdmBOMEXsi
Mar 23, 2005 03:18 PM
sivik2nr
Sep 27, 2003 03:48 PM
T-Mo
Sep 17, 2003 04:22 PM
H22ACiViC
Mar 21, 2002 08:12 PM
