Fitting a bov
Old Dec 21, 2007 | 04:52 AM
Powelly's Avatar
Default Fitting a bov
Noob question!
Anybody point me me to a thread or tell me how to fit the above?
the bov looks way to big for the hole on the ic piping, does the bottom half of the bov need to be welded to the piping then clamp the top half down with the clip to it or am i going mad?
Thanks alot.
Old Dec 21, 2007 | 05:12 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Fitting a bov (Powelly)
pics........what valve is it? you could weld it to the pipe, but that makes it permanent. pics and info.
Old Dec 21, 2007 | 10:04 AM
Powelly's Avatar
Sorry for the bad pics, all i had at the time. It's actually going on a friends b16 stock. XS power
Old Dec 21, 2007 | 10:13 AM
Powelly's Avatar
Tial copy! Just had a look at a few other pics and i think the bottom is supposed to be welded to the ic piping.
Thanks for your help bro.
Old Dec 21, 2007 | 11:14 AM
m R g S r's Avatar
Default Re: (Powelly)
flange is welded to the pipe not the actual bov itself. . .
Old Dec 21, 2007 | 11:32 AM
EJ1 wilcox's Avatar
Default Re: (m R g S r)
Those charge pipes look to be flanged for an RFL or similar BOV.
You have to remove the RFL flange and weld on the tial flange.
Old Dec 21, 2007 | 12:20 PM
Autoworks's Avatar
Default Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">Those charge pipes look to be flanged for an RFL or similar BOV.
You have to remove the RFL flange and weld on the tial flange.</TD></TR></TABLE>
Get a Tial 50mm flange.
Old Dec 21, 2007 | 12:49 PM
SD_Lurker's Avatar
HT White Ops
Default Re: (Autoworks)
Like stated above the piping has a flange for a different style BOV. You can get the Tial BOV flange and have it welded on the charge piping. As a matter of fact, I have a Tial BOV flange if you need one. Its aluminum so if your piping is steel then it won't work.
adhana2
Jun 2, 2003 02:16 PM
dirtySOHC's
Mar 2, 2003 02:21 PM
curiousgpnoy
Jul 18, 2002 11:09 AM
lsvtec101
Jun 15, 2002 09:40 PM
Snafu-Si
Feb 9, 2002 08:47 AM
