TB sensor gone....where can i get a new TB?
Hey guys, well i just found out that my TB sensor is gone, and i need a new TB....do n e of u happen to have a stock 00 Si TB at home, or know somewhere i can pick it up cheap??? my car just hit 70k so im hoping that this is just tune up shitt.....
Re: TB sensor gone....where can i get a new TB? (jdmBOMEXsi)
Just buy a used/working TPS sensor. You can then take off your TB and use a dremel to slot the little rivets that hold the sensor on. Then you can use a screwdriver to take it off. You'll need to adjust the sensor though, search around for the info on that aspect.
If you didn't install those things in your signature. And don't feel comfortable.. just get a used tps and goto the shop and have them do it. Only honda will tell you that you need an entire new TB... its just a sensor that can be taken off... replaced... and adjusted.
Re: TB sensor gone....where can i get a new TB? (splitime)
sweet...i installed those things on my sig, but thats wayy easy....no tampering required to existing parts....i just dont like to **** thigns up....cuz with my luck....i will thanks for the help tho
