Will this work
Old Apr 23, 2005 | 12:58 PM
IntegraTypeR's Avatar
Default Will this work
have a 99 USDM b16a2 block, crank and 4 mains
and
have a 95 JDM b16a block, crank and 5 mains
if i said that the b16a2 block is cleaner and want to use it...would this work:
B16a2 block + 99 or 95 crank + 95 b16a 5 mains + OEM bearings?
or do i still need a line/bore?
Modified by IntegraTypeR at 2:14 AM 4/24/2005
Old Apr 23, 2005 | 01:36 PM
rmcdaniels's Avatar
Have a machine shop check the clearances, but you will probably need a line bore/hone. It was tried on my B16A2 and they were way off.
Old Apr 23, 2005 | 01:40 PM
s2kdre's Avatar
Default Re: (rmcdaniels)
you have to look on the crank and the block for the numbers, so you get the right bearings thats all, it will work.
Old Apr 24, 2005 | 12:37 PM
Default Re: (jdmhonda)
the numbers of the mains are all cool....1,2,3,4,5 all there, but my main question i dont want to go with the fatter ACL bearings....want to go with the OEM bearings? is that possible?
Old Apr 24, 2005 | 12:39 PM
Default Re: (IntegraTypeR)
if anyone have any more reviews will be cool, but i guess it all depends on the garage if they say its ok or not
IAluder95
Mar 30, 2006 09:43 PM
cal_
Feb 6, 2005 12:32 AM
SpeedDreamz.com
May 19, 2004 08:34 PM
VanHonda
May 2, 2004 11:39 AM
