Block Sleeved and Crank wont spin
Well I had my block sleeved this winter and now I am putting it together. All of my main bearing clearances are on, but whenever I tighten the 5th main cap, the crank wont spin. I can tighten the other 4, but when the 5th is tightened, the crank wont spin. I really hope I dont ned to send my block back to the machine shop. Any ideas what it may be?
Thanks,
Craig
Thanks,
Craig
Re: Block Sleeved and Crank wont spin (VanHonda)
Measure ur clearances on the number 5 bearings bro, use a plastigauge and most likely the bearings you are using are off, then order new ones to spec
Re: Block Sleeved and Crank wont spin (VNTEC)
I allready measured them, they are on the tight side, but still within spec. It seems like if I can tighten all, but the 5th and have it spin, then it shouldn't need to be machined, but I could be wrong.
don't take any chances. take the block to a reputable machine shop and have them take a look at it. you won't regret it !
Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">align bore OR bent crank.</TD></TR></TABLE>
Re: (Dr Pooface)
The crank was stored inside my house so I dont think it would be a bent crank. I layed a straight edge across my main bearings and it seems like the center main is a bit higher than ther others so I think I need an align bore.
If I get an Align bore what is the best way to do the bearings?
thanks,
Craig
thanks,
Craig
Re: (VanHonda)
I was messin with it some more and I realized that the crank wont spin if the number 5 main cap is the only one installed so I am gonna try some new bearings to see if it fixes it.
Craig
Craig
Re: (VanHonda)
SAME EXACT thing happened to me. I made a thread about it. I threw some red honda bearings in the #5 main, and it helped a little. I switched to another block, so I don't need the red bearings, you want them? You can come pick them up from me if you want.
Re: (m R g S r)
If you store a crank on it's side for a long time, it can bend. But if you heat it up in an engine by spinning a bearing or wiping out a thrust, you better believe the heat will also bend the crank.
Pandahatch
28
02-27-2006 08:08 PM
Pandahatch
02-26-2006 10:08 AM
Jared
06-24-2001 09:53 AM
