will these work ok??
Old Sep 13, 2002 | 09:41 PM
91hatchcivic's Avatar
Default will these work ok??
hey i dont kno a whole lot about injectors, but im trying to turbo my zc, and i hear i need 440cc injectors.. do different ones make a big difference? could i use these and work ok ... http://www.zcar.com/classifieds/class_parts/13574
Old Sep 13, 2002 | 10:54 PM
ion_four's Avatar
Default Re: will these work ok?? (91hatchcivic)
no way to tell without seeing a pic. The DSM ones are almost identical to the honda, just a little bigger diameter, but you bore out the injector o-ring, so it works fine. These could be some odd shape and not work very well, but I'm sure they could be made to work to some extent. I'd go to http://www.dsmtrader.com and post an ad.
Old Sep 14, 2002 | 08:32 AM
Default Re: will these work ok?? (ion_four)
could i use 450cc injectors from a dsm and work the same? and does the year of the dsm make a difference in injector?
Old Sep 14, 2002 | 08:53 AM
genop's Avatar
To make the DSM injectors work you would have to get a resistor box from an older civic or run some 10watt 10ohm resistors inline with the injectors. Stock injectors are high impedance, DSMs are low impedance. But dont be turned off by that fact, I run them in my car and they work great
92_civic_lx
Nov 28, 2008 03:42 PM
b20hammer
Mar 22, 2004 01:10 PM
Adriano
Oct 15, 2002 06:53 PM
dbman96
Jul 18, 2001 01:53 PM
