will rsx injectors work in a b series?
I was planning on getting dsm injectors for my 00 si but didn't want to wire in the resistors. I know that type s(310cc) injectors can be modded to 520cc by cutting off the screen and ep3(270cc) can be modded to 490cc. This is what comptech does to the type s injectors with their supercharger kits. So i think since they are both high impedance would they just bolt with getting rsx injector clips? I have both lying around so this would be great if it worked.
Re: will rsx injectors work in a b series?
Here is a link on some RDX injector info for someof you guys. Hope this helps a little.
http://www.onecamonly.com/general-te...ctor-info.html
The red top adaptors for our Injector Dynamics injectors will adapt the RDX injectors to a B series or similar. They will make them 'normal' length and an 11mm top oring. We sell the adaptors for $12.50/ea if anyone needs them.
yes rdx injectors are great thats what i am running in my all motor k but i am looking to get the most fuel from a stock injector and for getting 520cc from stock type s's you can get for cheap is best bang for buck.
I think i will have to pick a set of those adapters off you where do i purchase them?
I got Siemens Deka 780's for $235 shipped, along with a resistor box; they're said to also have a spectacular spray pattern & very fine atomization. As for the RDX's at $50 a pop (connector + adapter) plus shipping, it doesn't seem like a spectacular deal. You actually have to do MORE wiring than a resistor box, 8 wires vs. 5. You could save money if you do what some Miata guys do - make a custom fuel rail with copper fittings. lol
However if you get them for almost nothing w/connectors, its a good deal...just like anything else you get for free. That's all that makes them a deal, IMO.
Modding stock WRX injectors, however, is an awsome deal. They are around ~760cc at that point, and lightly used injector sets sell for $100-150.
xenocron
Performance
93
07-21-2015 09:50 AM
xenocron
07-21-2015 09:50 AM
