Will Prelude Injectors Work
Old Jan 24, 2007 | 05:19 PM
bart2546's Avatar
Default Will Prelude Injectors Work
Got a question, in a previous post that I had about injectors, it was suggested that the injectors out of a 97 prelude with vtec would plug right into my car, (99 EX) meaning the wire harness and the o-rings and such would just pop right in, and would be a more powerful advantage since I am going boosted. Can anyone verify this information because someone on here is selling a set at what I believe is a decent price...the other question is that would I need to run any kind of resistor box or anything?? Or will they just pop in. Thanks in advance.
Old Jan 24, 2007 | 05:29 PM
spectacle's Avatar
Default Re: Will Prelude Injectors Work (bart2546)
I believe Prelude injectors are saturated vs the peak and hold type that d's and b's run & require a resistor box.
Someone will post after me and confirm this.
Old Jan 24, 2007 | 05:37 PM
bart2546's Avatar
Default Re: Will Prelude Injectors Work (spectacle)
Ok thanks for the info because that's what I want to avoid...please someone confirm this information to make my conclusion final?
Old Jan 24, 2007 | 05:42 PM
Danny_EJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spectacle &raquo;</TD></TR><TR><TD CLASS="quote">I believe Prelude injectors are saturated vs the peak and hold type that d's and b's run & require a resistor box.
Someone will post after me and confirm this.</TD></TR></TABLE>
Almost. Prelude injectors are peak and hold which require a resistor box unlike saturated injectors which B series come with stock
Old Jan 24, 2007 | 05:47 PM
bart2546's Avatar
Default Re: Will Prelude Injectors Work (Danny_EJ)
Ok so you're saying to put them in my Civic I need a resistor box, am I getting this right?
Old Jan 24, 2007 | 08:39 PM
Ruben19's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bart2546 &raquo;</TD></TR><TR><TD CLASS="quote">Ok so you're saying to put them in my Civic I need a resistor box, am I getting this right?</TD></TR></TABLE>
Old Jan 24, 2007 | 11:27 PM
Honda Sport's Avatar
4th gens are peak and hold, 5th gens are saturated
Old Jan 25, 2007 | 09:43 AM
spectacle's Avatar
Default Re: (Honda Sport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport &raquo;</TD></TR><TR><TD CLASS="quote">4th gens are peak and hold, 5th gens are saturated</TD></TR></TABLE>
so being that the 97 Prelude that the OP referred to is a 5th...the 'lude injectors should plug right up...
Old Jan 25, 2007 | 04:58 PM
Default Re: (spectacle)
you'll need obd1 injector clips to use obd1 injectors.
Old Jan 25, 2007 | 05:14 PM
genocide43110's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport &raquo;</TD></TR><TR><TD CLASS="quote">you'll need obd1 injector clips to use obd1 injectors.</TD></TR></TABLE>
But 97-up Preludes are OBD-II correct? So then he wouldn't need to worry about the clips. Also the Prelude injectors are only 280cc which is 40cc's more than the what you have now. Just thought I would let you know. Check out this link: http://s12.photobucket.com/alb...lude/ They should be good for up to about 224 HP.
Old Jan 25, 2007 | 05:49 PM
iBrandon's Avatar
Default Re: (genocide43110)
someone correct me if im wrong....but some 4th gen ludes came with 310cc...dun know exactly what years though..
Old Jan 25, 2007 | 05:50 PM
Default Re: (iBrandon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBrandon &raquo;</TD></TR><TR><TD CLASS="quote">someone correct me if im wrong....but some 4th gen ludes came with 310cc...dun know exactly what years though..</TD></TR></TABLE>
I didn't see 310 on the website I posted but I did see this:
1992-'96 Prelude VTEC Peak and Hold 345cc
Old Jan 25, 2007 | 06:01 PM
iBrandon's Avatar
i think ur right...heres what i searched...
obd1 h22a1 345cc = peak and hold injectors (need resistor box)
obd2 h22a1 345cc = peak and hold injectors (need resistor box)
obd2 h22a4 290cc = saturated injectors
I heard though that 345 flow like 310cc....but im guessing because they are not meant to max out...who knows! haha
Old Jan 25, 2007 | 06:04 PM
I don't mean to thread-jack but what would happen if I ran those injectors with my set up which is an H23A1 in a 1993 Prelude? Would it feed to much fuel? I plan on running an FMU because that is one of my only options. Every one says that 240cc isn't enough. Would they work ok or would I need something like a S-AFC? If I would need a S-AFC then I would just get some 440's.
Old Jan 25, 2007 | 06:13 PM
iBrandon's Avatar
If you could run anything but FMU i would...FMU is just not as reliable....a simple ecu tune on crome would be great if u can afford it...that would be the cheapest in my opinion over the FMU...
BUt if not...run the fmu...and go easy until u can rom tune
Old Jan 25, 2007 | 06:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBrandon &raquo;</TD></TR><TR><TD CLASS="quote">If you could run anything but FMU i would...FMU is just not as reliable....a simple ecu tune on crome would be great if u can afford it...that would be the cheapest in my opinion over the FMU...
BUt if not...run the fmu...and go easy until u can rom tune </TD></TR></TABLE>
I was talking to Xenocron about chipping a P06 I had and making a basemap for my setup and he said that it might not work with my auto TCU. So I asked and basically everyone said I was screwed. So I decided to go with an FMU because it was cheaper. I paid $32.61 for the missing link shipped and it was new. Now I just need an FMU and I'm going to be almost ready.
Edit: I just read one of my old threads on HMT and they say I could chip an ECU just not an auto P06. Xenocron is saying to run a P75 which is meant to be run with a TCU which my car has but the civics didn't.
caliprelude3087
Sep 6, 2004 05:39 PM
riceball777
Apr 27, 2004 10:21 PM
DelsolVtec18
Nov 25, 2003 07:23 AM
