Will a maxrev b-series kit fit on d-series with a d-series revhard mani?
Old 11-13-2003, 02:18 PM
pip9's Avatar
Default Will a maxrev b-series kit fit on d-series with a d-series revhard mani?
^question in title
I looking at buying a max rev b-series kit from this guy here on ht and i need to know if it'll bolt up to my d-series. I have a revhard t3/t4 mani i can use, i just need to know if the rest will bolt up, charge pipes, dp, ic, etc...
Old 11-13-2003, 02:38 PM
HELLO,GOOD MORNIN'
ahobbs's Avatar
Default Re: Will a maxrev b-series kit fit on d-series with a d-series revhard mani? (pip9)
yeah it should with just little modification. You may have to cut the webbing block a little. Most kits are pretty close to the same.
Old 11-13-2003, 03:45 PM
pip9's Avatar
i was worried more about the charge pipes and dp lining up correctly. The maxrev kits come with the flex pipe and all with the down pipes. I'm just wondering if it'll clear the oil pan etc... I'd probably have to do some fab. if i use the revhard mani too. I'll just run it straight off the dp
Old 11-13-2003, 03:53 PM
HELLO,GOOD MORNIN'
ahobbs's Avatar
Default Re: (pip9)
oh yeah i forgot about the down pipe. Yeah that will be different.
yostuhfoo
12-11-2008 03:44 PM
Sil84
Southeast (Sales)
39
03-26-2008 10:38 AM
lanojp1
07-12-2005 08:38 AM
turbotime
12-17-2003 07:44 PM
Quick Reply: Will a maxrev b-series kit fit on d-series with a d-series revhard mani?
