will the heat from a turbo cause damage
Old Jan 17, 2004 | 01:05 PM
b18bEG's Avatar
Default will the heat from a turbo cause damage
will the heat from a turbo cause damage to a CF hood, warping, cracking all that bull ****, im pondering on getting a cf again, but i dont wanna waste my money on somthing that will get all jacked up. thx for the input
Old Jan 17, 2004 | 02:16 PM
RedTegLS's Avatar
Default Re: will the heat from a turbo cause damage (b18bEG)
I dont know if this will help............
https://honda-tech.com/zerothread?id=735966
Old Jan 17, 2004 | 02:22 PM
SpdRcrChk's Avatar
I'm not sure about this one. But I believe they DO sell heat shield material that you can place underneathur hood.
Old Jan 17, 2004 | 02:44 PM
turbolude92's Avatar
I have a VIS invader CF hood with the vent. It helps dissipate heat and so far i have had no fading. However, right where the vent is i have noticed little cracks. I believe it is from the heat. Ony my prelude though, the turbo mounts only a couple of inches away from the hood so that is probably the source. I have had it on for about 6 months.
Old Jan 17, 2004 | 10:29 PM
b18bEG's Avatar
Default Re: will the heat from a turbo cause damage (RedTegLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote">I dont know if this will help............
https://honda-tech.com/zerothread?id=735966</TD></TR></TABLE>
i had already read all the way thru that post, and didnt really find a definate, or close answer. Im looking to see if anyone has anydirect experiances with the problem, if it is even a problem. any one else?
also, will thermo-sheild or thermo-wrap, or what ever the ***** its call do the trick jsut fine, so i woulnt have to worry about it ever?
Old Jan 17, 2004 | 11:28 PM
stinker504's Avatar
I have no heat shield of any kind and my CF hood is holding up perfectly. I can put my hand on the hood after a long run and almost burn myself. I've taken several courses on materials and composit materials and know for a fact composits are designed for high heat.
Old Jan 18, 2004 | 02:55 AM
johnsona's Avatar
i have a d16z with a turbo and no heat sheild and i dont have any cracks in my hood. they uses a clear apoxy urathane gel to seal a good carbon fiber hood the only way i can see ic cracking is if the hood stayed up to long it get some stress cracks but they use that **** on fighter plains and they get more heat stress then a simple turbo and the dont crack i dont know iff this helps you but i would say you have nothing to worry about just dont buy crap
Old Jan 18, 2004 | 03:56 AM
b18bEG's Avatar
Default Re: (stinker504)
[QUOTE=stinker504]I have no heat shield of any kind and my CF hood is holding up perfectly. I can put my hand on the hood after a long run and almost burn myself. I've taken several courses on materials and
Which CF do you have on your car?
Old Jan 19, 2004 | 02:46 PM
b18bEG's Avatar
bizzup because it 2:46Am over here in iraq
Old Jan 19, 2004 | 02:48 PM
grndcont's Avatar
how goes the battle over there?
Old Jan 20, 2004 | 03:22 AM
b18bEG's Avatar
where im at I dont see any, im with a rescue unit, so we dont see any fighting. good thing
bard329
Mar 1, 2006 06:51 PM
EJ8 GSR-T
18
Jan 20, 2006 11:05 PM
Ls InTeGrA RaCeR
May 19, 2005 12:47 AM
zippeay
Aug 22, 2003 10:16 AM
Boostless97Lude
Sep 7, 2002 09:04 AM
