Will 4bolt downpipe bolt up to 5bolt hotside?
Old Dec 30, 2006 | 02:26 PM
turbotime's Avatar
Default Will 4bolt downpipe bolt up to 5bolt hotside?
Will a 4bolt downpipe bolt up to a 5bolt hotside? I know all 4 holes wont line up but will 3 of the 4 line up? Do you think it will seal or will it leak?
Thanks
Old Dec 30, 2006 | 02:44 PM
non-VTEC's Avatar
Default Re: Will 4bolt downpipe bolt up to 5bolt hotside? (turbotime)
if you take the turbo off you may be able to drill and tap a new hole in the proper location.........if you only run the 3 bolts you will probably have a leak.......
Old Dec 30, 2006 | 03:58 PM
wantboost's Avatar
Who is Mr Robot?
uh... dont be a cheapass. weld a new flange on
Old Dec 30, 2006 | 08:50 PM
HiProfile's Avatar
If you look at the 4-bolt housing and the 5-bolt housing, even if the bolt spacing was the correct for the 3 on the 5-bolt, its still 45 degrees off. If you take a 4-bolt housing out and replace it with a 5-bolt w/o moving anything else, NO holes will line up. Even if it does somehow work with 3 bolts, that 4th will leak, even if the flange is warped in on that side (like a lockwasher). It won't sound too great, heat up the engine bay, and introduce quite a bit of 'dead' air in there, gases that will not combust if put into the cylinder.
Spend the extra $75 to get it done right. You give hondas & turbocharging a bad name when you do things half-*** w/o the HMT element added in for laugh factor. I'd rather see a 4-bolt flange welded to the 5-bolt housing with a flux-core welder and bird-**** welds all over - and making it work w/o leaks while laughing at yourself - than a 4-bolt flange on a 5-bolt housing.
Old Dec 31, 2006 | 11:45 AM
turbotime's Avatar
yup just a question, i dont plan on doing this myself i was askin for a buddy
Old Dec 31, 2006 | 11:53 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (turbotime)
go slap him
Old Dec 31, 2006 | 01:03 PM
project dc2's Avatar
Default Re: (wantboost)
the 4 bolt also has a diffrent position and sits farther into the block
Old Dec 31, 2006 | 02:36 PM
b18sihatch's Avatar
u could make a adapter
TurboEM1
Oct 1, 2006 05:59 PM
brent_G
Sep 8, 2005 03:19 PM
b18cEF9
Mar 31, 2005 07:23 PM
DubyaAye
Jun 27, 2004 08:07 AM
BlueSi2k
Mar 31, 2004 01:56 PM
