Wierd smoking problem
Old Sep 13, 2005 | 12:39 PM
green91's Avatar
Default Wierd smoking problem
Sup,
Ive been pulling my hair out trying to figure out my car's smoking problem. It smokes some under boost (i understand some black smoke is ok since im running 12.1:1 AFR) but when i engine brake down hills and then hit the gas, POOF a big puff of oil smoke. Ive ran compression check - 175-180 across the board.
Ive recently fixed my oil return line.. it doesnt smoke near as much under boost now. Im curious if the turbo seals could cause the car to smoke when i engine brake and then hit the gas.. and if so, how? I realize that valves seals would also cause a similiar problem. I was running a stock PCV system and a catch can (yes i know, wrong way) to the valve cover, and disconnected both of them to see if it made any change and it didnt.
Any ideas? The turbo has a very very slight amount of side to side play but nothing i would consider excessive.
BTW, this is on a d16z6 in an EF with a dsm t25
this is also with 5w30 mobil oil.
Modified by green91 at 4:51 PM 9/13/2005
myessay
Jan 27, 2012 01:59 AM
dc2doi
May 15, 2009 11:48 AM
krazyhmongboi
May 1, 2009 03:47 PM
cooltron
Mar 28, 2008 01:54 AM
crispydee
Aug 4, 2004 10:41 AM
