wierd idle
Old Feb 4, 2004 | 05:50 PM
paul93sir's Avatar
Default wierd idle
hey guys need some help one of my customers brought me his car thaty he had built by some one else and it has a erratic idle between 1k to 2k after it warms up i checked the iac valve and its ok cleaned it out and reinstalled it and i also tried another fast idle thermo valve and still the same thing i would appreciate any help i have fixed many of these problems before but this one is wierd
Old Feb 4, 2004 | 06:47 PM
Jdm93civic's Avatar
MAF sensor? throttle body........?
Old Feb 5, 2004 | 05:21 AM
paul93sir's Avatar
if this helps it is a gsr turbo motor that he has in the car
Old Feb 5, 2004 | 06:53 AM
Nid Styles's Avatar
Default Re: wierd idle (sir2t)
Air in the head?
Old Feb 5, 2004 | 10:19 AM
platinum00's Avatar
Default Re: wierd idle (nd_styles)
vac leak
make sure the trottle body gasket is not on backwards.
platinum.
Old Feb 5, 2004 | 10:22 AM
Pfieff's Avatar
I know you said you cleaned out the IAC, but are you sure that it is functioning correctly. If you unplug it while the car is warm and running, what does it do?
Old Feb 5, 2004 | 10:37 AM
808b18c1boosted's Avatar
Default Re: (Jdm93civic)
honda have a map sensor not a maf sensor, check if the map sensor poped out of the bleeder vavles.
Old Feb 5, 2004 | 11:26 AM
psileepR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir2t &raquo;</TD></TR><TR><TD CLASS="quote">hey guys need some help one of my customers brought me his car thaty he had built by some one else and it has a erratic idle between 1k to 2k after it warms up i checked the iac valve and its ok cleaned it out and reinstalled it and i also tried another fast idle thermo valve and still the same thing i would appreciate any help i have fixed many of these problems before but this one is wierd </TD></TR></TABLE>
what is he using for engine management? any cels?
elli
Jun 1, 2010 01:22 PM
heyitzspikey
Jan 29, 2007 09:19 PM
I Like Hondas
Jun 11, 2006 05:35 PM
mikeunreal
Oct 26, 2005 05:31 PM
CA6VTEC
Sep 14, 2004 05:57 PM
