Wideband o2 placement
Old Jul 11, 2008 | 07:28 AM
Si GUY99's Avatar
Default Wideband o2 placement
I was curious as to where everyone else put their wideband o2 and how you have it set up. I've read and been told many things about being lean or to hot for the o2 and so on b/c of not having it in the right spot and I'm just tryin to get somewhat of a final answer. I have vortech kit 99 Si, My plan was to put a 2nd bung in my test pipe for the wideband (good spot?) So basically in the header would be the primary o2 then in the begining of the test pipe would be the one for the wide band and to the back of the test pipe would be the secondary o2 any help is appreciated . I have the PLX afr/dm5 set up
Old Jul 11, 2008 | 07:52 AM
MadScientistMatt's Avatar
Default Re: Wideband o2 placement (Si GUY99)
As a general rule, you can't go wrong with about 18" or a bit more after the turbo, and in the top half of the exhaust pipe. Some widebands can overheat if they're too close to the turbo.
Old Jul 11, 2008 | 02:10 PM
inspyral's Avatar
Generally you want it to be 12-30" after the turbine on a turbo setup, but in your case, at the collector of the header or anywhere after it should work well. As stated above, it should be at least 10degrees above horizontal so that condensation can't build up on it. A second bung in your test pipe should be fine.
Old Jul 11, 2008 | 03:34 PM
all_motorsi's Avatar
Default Re: (inspyral)
Mine is about 6" away from the turbo and I haven't had any problems... I do need to move it tho
Old Jul 11, 2008 | 06:55 PM
cjordan's Avatar
Default Re: (all_motorsi)
mine is about 15 inches from turbo and dont have any issues at all
Old Jul 11, 2008 | 07:56 PM
blinx9900's Avatar
Default Re: (cjordan)
I got mine 4" from the turbo
Old Jul 11, 2008 | 08:40 PM
Si GUY99's Avatar
Default Re:
Thanks everyone sounds good, in the test pipe its going roughly 1-2 o'clock position
Jayman_Gsr
Nov 20, 2008 05:22 AM
RSant
Oct 25, 2006 01:09 PM
IntegraCF21
Sep 24, 2005 04:42 AM
VTEConly
Aug 31, 2005 12:13 PM
