wideband
Old Oct 9, 2003 | 10:10 PM
mattcalica's Avatar
Default wideband
okay, this may be a stupid question, but can you hook up a autometer a/f guage to a wideband bosch sensor? would this make the readings a lot more accurate? if its not possible, then is an egt guage a lot more accurate than a a/f guage?
Old Oct 9, 2003 | 10:13 PM
LsTurbo91's Avatar
Default Re: wideband (mattcalica)
No you cannot, you need a wideband controller to drive the sensor etc.,
An Egt gauge is not in the same line as a Air Fuel gauge, that's why its called Exhaust Gas Temp.
Old Oct 9, 2003 | 10:26 PM
mattcalica's Avatar
but the egt guage can give you a idea of whether you are running rich or lean based on the temperatures of the gases, right? so are egt guages accurate as far as those readings go?
Old Oct 10, 2003 | 04:59 AM
Poop111444's Avatar
Default Re: (mattcalica)
An EGT gauge is a better monitoring tool then the narrowband autometer AF gauge. Im already have a Wideband o2 and Im getting an EGT as well!
rohec04
May 26, 2009 11:34 AM
doublejz
Jan 14, 2004 05:31 AM
Loco Honkey
Nov 10, 2002 10:40 PM
T3EMSI
Jun 21, 2002 11:38 AM
Ri5e
Jun 17, 2002 08:50 AM
