why would vacum change with the install of a boost controller?
Old Dec 4, 2001 | 09:36 AM
DIRep972's Avatar
Smarter than you
Default why would vacum change with the install of a boost controller?
Im using a Turbo XS manual boost controller, with the boost controller hooked up my vacum(greddy boost gauge) sits at -450.. isnt -500 or below what its supposed to sit at? Well I unhooked the BC and my vacum went down to -550 where it should be.. What would be causing this? defective boost controller? too many vacum lines hooked up to one spot maybe?
[Modified by DIRep972, 8:15 PM 12/4/2001]
Old Dec 4, 2001 | 09:40 AM
Flamenco-T's Avatar
Default Re: why would vacum change with the install of a boost controller? (DIRep972)
it may be like you dais, too many vacuum tap in to one source...
try to do it evenly, between the vacuum sources...
I might be by later on tonight..
stan
Old Dec 4, 2001 | 09:57 AM
JM Performance's Avatar
Default Re: why would vacum change with the install of a boost controller? (Flamenco-T)
mine sits at -600. but its still a NA car. no turbo in yet.
S2Kustom
Honda S2000
Sep 26, 2008 09:02 AM
ericstambaugh07
Jul 4, 2007 11:13 AM
Mucackus
Apr 26, 2002 08:45 AM
