Why are low comp headgaskets bad?
Old Jun 19, 2004 | 06:42 PM
Overkill's Avatar
Default Why are low comp headgaskets bad?
Whenever I see someone bring up a thicker headgasket as an alternative for lowering compression its always frowned upon. Why? Is it just because someone may get the wrong idea and think that now the stock internals can take much more boost? Thanks
Old Jun 19, 2004 | 08:52 PM
PM-Performance's Avatar
Default Re: Why are low comp headgaskets bad? (ricerhater)
why is everyone concerned with more boost? you should be worried about HP not boost
anyway the headgaskets are a good way to make the motor a little safer. as far as i know that will be more likely to go before anything else since its thicker, which is better then bottom end **** blowing. but with the headgasket being soo much thicker you need to compensate for timing being different.
Old Jun 19, 2004 | 11:02 PM
Briansturboteggy's Avatar
Default Re: Why are low comp headgaskets bad? (itr206)
thicker head gasket is gay, and yes you should be more concerned with hp, and not boost
Old Jun 20, 2004 | 12:46 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
some people dont like them because it moves the quench area further away from the piston top or crown..i guess it all depends on what type of head(chamber) shape/type and piston combo u are using to really make a difference..in optimal burn...
maybe there not bad ..i guess it all just depends on the setup..
Old Jun 20, 2004 | 05:13 AM
TeamCracka's Avatar
Default Re: Why are low comp headgaskets bad? (Briansturboteggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Briansturboteggy &raquo;</TD></TR><TR><TD CLASS="quote">thicker head gasket is gay</TD></TR></TABLE>
Dumbass
Old Jun 20, 2004 | 05:59 AM
danl's Avatar
Banned
Default Re: Why are low comp headgaskets bad? (bruceleeroy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceleeroy &raquo;</TD></TR><TR><TD CLASS="quote">some people dont like them because it moves the quench area further away from the piston top or crown..i guess it all depends on what type of head(chamber) shape/type and piston combo u are using to really make a difference..in optimal burn...
maybe there not bad ..i guess it all just depends on the setup..</TD></TR></TABLE>
Thats why I don't like them.
Old Jun 20, 2004 | 06:33 AM
TurboJesse
Guest
Posts: n/a
Default Re: Why are low comp headgaskets bad? (danl)
I run one on my b16a, ran 14-15psi daily on my old setup and plan to run 17-18 on race gas with my new setup (im hoping for around ~375whp).
Old Jun 20, 2004 | 06:56 AM
Overkill's Avatar
I'm not concerned w/ more boost im just interested as to why every is always against using it. But, along with a well built and efficeint setup more boost does equal more power, Right??
jerzey908
Jul 13, 2016 07:02 PM
avotegra
Jan 19, 2010 11:14 PM
poormans_typer69
Jul 22, 2008 03:07 PM
SiTR
Jan 11, 2007 10:00 PM
speed
Nov 23, 2002 05:18 PM
