why cant i boost??HELP
Old Feb 7, 2004 | 01:08 PM
iwouldHITit's Avatar
Default why cant i boost??HELP
my car wont let me boost..when every it starts to boost the motor starts to sputter..i have a crxls with SMC and dsm 450cc..how do i fix this
Old Feb 7, 2004 | 01:11 PM
b16ahybrid's Avatar
Default Re: why cant i boost??HELP (iwouldHITit)
check valves or mising link
search those
Old Feb 7, 2004 | 01:13 PM
Default Re: why cant i boost??HELP (b16ahybrid)
i thought i wouldnt need check vavles or missing link if im using my SMC..and i have no CEL
Old Feb 7, 2004 | 01:14 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwouldHITit &raquo;</TD></TR><TR><TD CLASS="quote">i thought i wouldnt need check vavles or missing link if im using my SMC..and i have no CEL </TD></TR></TABLE>
I've never used the smc so i cant verify that....maybe you have it wired wrong?
Old Feb 7, 2004 | 01:17 PM
nah my wiring should be good cause i was boosting before but only last night it start to not let me boost..
Old Feb 7, 2004 | 04:28 PM
help
Old Feb 8, 2004 | 01:32 PM
dgcivic's Avatar
hmmmmmmmmmmm
Old Feb 8, 2004 | 01:39 PM
dgcivic's Avatar
no cel. no boost. engine in good shape?
Old Feb 8, 2004 | 02:11 PM
Default Re: why cant i boost??HELP (dgcivic)
yupp engine still runs strong..
Old Feb 8, 2004 | 04:11 PM
RedStarGsr's Avatar
check all intercooler piping, vaccuum lines...do you hear the turbo spooling up just no boost?
Old Feb 8, 2004 | 08:11 PM
velocitytrends's Avatar
Default Re: (RedStarGsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedStarGsr &raquo;</TD></TR><TR><TD CLASS="quote">check all intercooler piping, vaccuum lines...do you hear the turbo spooling up just no boost?</TD></TR></TABLE>
ahhhh beat me to it! Def check your cuplers on all your piping all of them. From the I/C to the I/M. Thats a must! Good Luck!
Old Feb 8, 2004 | 08:20 PM
B18bEK's Avatar
Default Re: (velocitytrends)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by velocitytrends &raquo;</TD></TR><TR><TD CLASS="quote">
ahhhh beat me to it! Def check your cuplers on all your piping all of them. From the I/C to the I/M. Thats a must! Good Luck!</TD></TR></TABLE>
check this
Old Feb 8, 2004 | 08:21 PM
all the pipes are good...its when it starts boosting it starts to sputters...like misfiring..
Old Feb 8, 2004 | 08:28 PM
lazerus's Avatar
Default Re: (iwouldHITit)
it could be wayyy rich.
Old Feb 8, 2004 | 10:19 PM
Cruiser G's Avatar
Default Re: (lazerus)
spark plug gap?
Old Feb 9, 2004 | 12:21 AM
Default Re: (Cruiser G)
plugs are gap .32 and are nkg 2range colder plugs...
i think i might of hooked up my SMC wrong whats the pinout for the MAP on the ecu...b18 obdo?
Old Feb 9, 2004 | 12:42 AM
Group Tenacity's Avatar
I had a simular problem a while back. it turned out the fuel pump was going out and it would lean out and the sputtering instead of boosting was detonation.
could be a problem with your fuel system as well..
Old Feb 9, 2004 | 11:18 AM
dgcivic's Avatar
Default Re: why cant i boost??HELP (Group Tenacity)
what the base fuel psi? sounds like the same prob with my old honda. check the pcv valve(they tend to build up with carbon!)
Modified by dgcivic at 4:28 AM 2/10/2004
Old Feb 9, 2004 | 01:30 PM
BlackKnight7's Avatar
Is the turbo working alright? I had a problem like this, what happened was the nut holding the compressor wheel on the shaft had backed off and the wheel was jamned. The motor ran fine, but when right as I should have been building boost it would sputter, not build boost, and blow smoke out the tail pipe.
Also I have had IC pipes come off enough so that I wasn't getting any pressure in the intake manifold, while the turbo was building boost.
Jake D.
Old Feb 9, 2004 | 01:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dgcivic &raquo;</TD></TR><TR><TD CLASS="quote">what the base psi?</TD></TR></TABLE>
What the sentence mean? What is base psi? He said he wasn't building any boost, so why does "base psi" have anything to do with it?
Jake D.
Old Feb 9, 2004 | 01:38 PM
Tinker219's Avatar
Default Re: why cant i boost??HELP (BlackKnight7)
Make sure youre accounting for the extra "bleep" on the SMC. I was dialing %25 out instead of 35%, which was causing exactly the same condition you are describing.
Also, double-check your wiring...Ive had problems with the provided diagrams being WRONG, which will really screw things up.
Old Feb 9, 2004 | 07:35 PM
Default Re: why cant i boost??HELP (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure youre accounting for the extra "bleep" on the SMC. I was dialing %25 out instead of 35%, which was causing exactly the same condition you are describing.
Also, double-check your wiring...Ive had problems with the provided diagrams being WRONG, which will really screw things up.</TD></TR></TABLE>
yea i think i wired the MAP wrong...the diagram they gave is kinda hard to understand...anyone know the MAP pin out on the ecu?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Group Tenacity &raquo;</TD></TR><TR><TD CLASS="quote">I had a simular problem a while back. it turned out the fuel pump was going out and it would lean out and the sputtering instead of boosting was detonation.
i know my fuel pump is good cause im not leaning out my plugs are black..2range colder ngk plugs gaped at .32
elpiar
Mar 22, 2005 06:02 PM
TRE_
Nov 7, 2004 12:26 AM
rusteds2k
Feb 7, 2004 10:56 AM
wickedxboi
Dec 24, 2002 06:42 PM
freeplay
Sep 8, 2002 08:59 PM
