Coolant question.
Coolant question.
not to sound like a noob, but i just put coolant on the coolant tank resevoir 2 days ago and when i checked today, it was below the low mark. I opened the radiator cap and it was full. Is this normal? should i put more coolant inside the tank?
Re: Coolant question. (blemar56)
your question makes no sense. You put stuff in the overflow bottle, the radiator itself is always full, you dont want air in there.......closed system. The level of coolant in the overflow will vary if the engine is warm or not.
Re: (blemar56)
You are talking about the Overflow tank correct, that is what it is an overflow tank, it doesn't need to be full, it doesn't even need to have fluid in it. Just make sure your radiator is full when it is cool. It will fill up if the engine is getting to hot and needs to release pressure.
djork
01-07-2011 12:55 AM
ATS*Mark
12-20-2003 09:37 PM
