who use brass fittings Straight on the turbo?
Re: who use brass fittings Straight on the turbo? (Tactic$)
1/8" NPT
But you'd be better off plugging that port and running the vacuum to the intake manifold.
Intercoolers cool air, so they drop the volume of the air, so pressure drops across them.
Re: who use brass fittings Straight on the turbo? (Wideopentuning)
I'm using straight brass fittings for my coolant lines... works fine.
I've seen them used for both oil and coolant, so I don't think you will have a problem.
JDMCRX
08-22-2003 08:14 AM
