white smoke
Old Sep 16, 2006 | 09:42 AM
ragethemachine86's Avatar
Default white smoke
Car started smoking white out of the exhaust, no cat. Blown engine? Piston rings? I was late on my oil change.
Old Sep 16, 2006 | 11:26 AM
turbo_ls_69's Avatar
could be your turbo seals, does it smoke at idel or after you boost it?
Old Sep 16, 2006 | 02:19 PM
20yrsToMidnight's Avatar
Default Re: white smoke (ragethemachine86)
Just start by looking for oil in the downpipe, if there is none start checking other things... compression, headgasket, etc.
Old Sep 16, 2006 | 06:43 PM
Default Re: (turbo_ls_69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_ls_69 &raquo;</TD></TR><TR><TD CLASS="quote">could be your turbo seals, does it smoke at idel or after you boost it?</TD></TR></TABLE>
only under some load in boost. afterwards it will smoke a little at idle, like a minute max. will check compression and oil residue in DP tomorrow.
Joeski99Si
Aug 2, 2009 11:25 AM
ACrite3404
Jun 27, 2008 02:31 AM
BOOSTD4dR
Mar 11, 2007 09:59 AM
petrv
12
Jul 14, 2003 06:33 AM
sushibug
May 29, 2002 03:52 PM
