white smoke
Old Feb 17, 2002 | 12:08 PM
808eg6's Avatar
Default white smoke
well heres the prob. my car emits white smoke every so often at idle for a minute or so from the exhaust. what could that be from? i'm pretty sure my turbo seals are blown, so could it be from that or something else. oil level is fine and so is coolant. never did a compression test yet, so could it be a blown head gasket.
thanks in advance
Old Feb 17, 2002 | 01:00 PM
MiraiZ's Avatar
Default Re: white smoke (808eg6)
try a compression test....it could just be from condensation from cold weather or it could be signs of a bad head gasket..
Old Feb 17, 2002 | 06:28 PM
TurboR's Avatar
New User
Default Re: white smoke (MiraiZ)
Ur turbo seal are blown for sure.. White smoke is caused by that..
Old Feb 19, 2002 | 10:07 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
maybe your fuel pressure is set to high, my car was putting off a little smoke at idle and would then go away during acceleration. I lowered my fuel pressure reg. and no smoke
Old Feb 19, 2002 | 11:38 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: white smoke (not so civic)
Now, does this just happen when you are warming up the car. Because at idle when the car warms up, and with no cat, you will get while smoke from the condensation in the cylinders. Kinda like when you have a ice cold coke and it builds up condensation on the outside of the cup. Well same thing is happening, but the heat is buring it through your exhaust and it looks like its smoking. You did say it didnt do it all the time that is why Im thinking this.
art
bpfergu
Mar 5, 2012 05:27 PM
b16nonoy
Feb 22, 2007 09:57 AM
dominate9
Jul 13, 2006 12:40 PM
turbolude99
Nov 5, 2004 01:02 PM
