where to mount my EGT probe?
Old Jul 6, 2004 | 09:58 AM
djnikko's Avatar
Default where to mount my EGT probe?
as the title says.... before the turbo? after the turbo? downpipe or manifold? Ive heard people say that my EGT probe could break off and **** up my turbo if i put it before and apparently the readings are useless when putting it after the turbo? what you guys reckon...The EGT probe and gauge is made by "trust" if that helps
thanks
Old Jul 6, 2004 | 10:09 AM
djfob's Avatar
I've got mine in the #3 runner on mani. You get a more accurate reading and I've never heard of a probe breaking off before.
Old Jul 6, 2004 | 10:10 AM
tgreaves's Avatar
Default Re: (djfob)
Mine is ran before the turbo..
Old Jul 6, 2004 | 11:25 AM
underpressure02's Avatar
Default Re: where to mount my EGT probe? (djnikko)
number #3
and next time search this is asked atleast 3 times a week.
Old Jul 6, 2004 | 11:48 AM
integra-modder's Avatar
The question is, do you trust your "trust" guage and accessories?
If the sensor isnt a complete waste of money, then I cant immagine it breaking off unless its installed incorrectly. The EGT guage is used to give you an idea of what the temperatures are inside the combustion chamers, inorder for this to happen, it needs to be placed AS CLOSE AS POSSIBLE to the combustion chamber.
Cylinder #3 is usually argued to be the hottest because of block design and coolant flow so runner #3 is usually the best spot for your EGT sensor.
Old Jul 6, 2004 | 11:52 AM
tgreaves's Avatar
Default Re: where to mount my EGT probe? (integra-modder)
I am running a crx hf manifold with an adapter plate.. I put the egt sensor where the factory o2 sensor was on that manifold.. I have seen a few others do it and I guess ill have to see how it works.. I have it in there but havnt ran the wires for it yet(im lazy)..
Old Jul 7, 2004 | 12:43 AM
djnikko's Avatar
Default Re: where to mount my EGT probe? (tgreaves)
thanks for the replies guys. I have the HF manifold also so i may do this, but im guessing i need a reducer of some sort something like a 1/2inch male NPT to 1/4 female? in order to fit the probe in place of where an o2 sensor used to go?
Old Jul 7, 2004 | 01:08 AM
turbopimp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the replies guys. I have the HF manifold also so i may do this, but im guessing i need a reducer of some sort something like a 1/2inch male NPT to 1/4 female? in order to fit the probe in place of where an o2 sensor used to go?
If you're going to use the O2 fitting to mount your EGT probe then you'll need a M18 X 1.5 bolt drilled out to the size of you're EGT probe fitting.
Old Jul 7, 2004 | 05:57 AM
tgreaves's Avatar
Im using the AEM egt probe and it comes with a weld in bung.. I had a local shop drill out the o2 sensor hole and weld in the bung..
Old Jul 7, 2004 | 07:12 AM
When do you plan on wiring that up? Im considering getting an AEM EGT probe just so I can log some of the EGT's
Old Jul 7, 2004 | 07:16 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">When do you plan on wiring that up? Im considering getting an AEM EGT probe just so I can log some of the EGT's</TD></TR></TABLE>
Hopefully tonight..
Btothe3rdDegree
Aug 16, 2004 05:14 AM
Blindstuff
Jun 2, 2004 09:51 AM
MachAF
Jun 21, 2003 06:02 AM
civictypenos
Oct 4, 2002 01:55 PM
Crxlsturbo
Aug 5, 2001 01:05 PM
