Is securing vacuum hose necessary?
Old Nov 19, 2003 | 08:01 PM
5thgencivic's Avatar
Default Is securing vacuum hose necessary?
I was just curious if securing the hose with small clamps, zip ties, etc is necessary for higher boost. I'll be running 1 bar max, but do you high boost guys clamp them down because of the high pressure? Or is it not needed? Been wanting to know thanks.
Nate
Old Nov 19, 2003 | 08:09 PM
BodyKits NW's Avatar
Default Re: Is securing vacuum hose necessary? (5thgencivic)
I use zip ties on most of my vacuum lines such as BOV, FPR and 3BAR Map. Everything else such as wastegate and brake vac. I use clamps. Seems to be working fine for me.
Old Nov 19, 2003 | 08:43 PM
Ri5e's Avatar
You don't have to clamp them. The only one I would recommend clamping down is the vacuum line to and from the wastegate. You don't want that line to blow off while' you're boosting 14 lbs
Old Nov 19, 2003 | 09:11 PM
Default Re: Is securing vacuum hose necessary? (Dr. Boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. Boost &raquo;</TD></TR><TR><TD CLASS="quote"> You don't want that line to blow off while' you're boosting 14 lbs </TD></TR></TABLE>
Exactly, hehe. Ok, thanks guys. I'll probably clamp the wastegate line and zip tie the rest of the stuff just to be on the safe side. one less thing to worry about
Old Nov 19, 2003 | 09:39 PM
Bailhatch's Avatar
yup at least zip-tie them all. A guy near me blew off his WG actuator line and then blew his motor....
Old Nov 19, 2003 | 09:48 PM
SIK IN DA HED's Avatar
New User
clamps AND zip ties are your friend.
Old Nov 19, 2003 | 11:12 PM
IN VTEC's Avatar
I've had a friend blow off a vacuum line that the GReddy pressure sensor referenced off of after only hitting 3psi. I say use clamps where possible and ziptie at the very minimum on lines that will see positive pressure.
acrocat
Jun 30, 2009 08:23 PM
.RTErnie
Welding / Fabrication
48
Feb 24, 2009 04:16 PM
Mario.
Oct 5, 2004 03:12 PM
red_sir
Feb 4, 2003 06:50 PM
b18bvudoo
Jun 29, 2002 11:08 PM
