where can i find this stuff?,need help!
Ok,here is the deal,i need a gasket to mount a t3 turbo to the manifold right(to seal it)??also i need a gasket to mount the downpipe to the turbo right??? if so where can i find these???
Bov and wastegates usually come with gaskets/seals right???
this is all that is holding me back from buying and piecing together my kit!!
You can find a gasket to go between the turbo and manifold here:
http://www.atpturbo.com/Mercha...e=GSK
What turbo are you running? Most people don't use a gasket between the turbo and downpipe (myself included) they just aren't needed.
P.S. If your wastegate doesn't come with gaskets you can buy them from ATP as well.
Gaskets....we don't use no stinking gaskets!!!!!
Don't need one between mani and turb and turbo and downpipe as long as your surfaces are truely flat. (which they should be)
jb0705
May 16, 2006 11:23 AM
