Where can I find information on Garrett turbo?
I bought a used turbo off someone and was wondering where I could find additional information on this turbo. I have the part #. 466159-5004?
Re: Where can I find information on Garrett turbo?
Moderator
Ah yes, the turbo you listed is the T3/T04E 60 "trim" turbocharger using a stage III 2.559" T31 wheel diameter, and 76mm exducer & 58mm inducer compressor wheel.
The standard bearing system is a 270 degree thrust bearing system in a 2.5" 4 bolt .63A/R turbine housing. Capability is about 430whp give or take a few. maximum efficiency is at 22psi for a Honda engine. turbobygarrett will not list this part number.
RyanAutry
01-05-2003 10:43 AM
