where can i find bracket to support ramhorn manifold?
i heard ramhorn manifolds may crack if not braced up,cause due to the weight of turbo and manifold,any info would be appreciated.
1 Post
Re: where can i find bracket to support ramhorn manifold? (turbomoe)
Most of the higher quality manis come with warrantys against cracking.
But if you're talking SSauto ... get a shop to weld some for you ...
you're going to have to make one man, or get a shop to. what u actually need is a bracket to hold the turbo in the air without a mani bolted that way u know all the weight is on the bracket instead of the mani.
same thing with the wastegate if u are going to use an ssac manifold
goodluck on that
goodluck on that
Beave0101
07-13-2003 07:11 PM
