when running a newly built motor.
Old Apr 20, 2011 | 01:28 PM
sh!ft's Avatar
Who the fack changed my title?!
Default when running a newly built motor.
Is it more logical to run the motor on a stock ecu, then add the tuning equipment to it and THEN take it to get tuned? for instance, drive the ammount of time/mileage to break in the motor, add the tuning equipment and drive it to the tuner?
Old Apr 20, 2011 | 01:37 PM
MR.johnson's Avatar
Default Re: when running a newly built motor.
your motor is going to be different than stock. IE compression, stroke, cams. strap it down and break it in on the dyno.
Old Apr 20, 2011 | 02:39 PM
evilclown312's Avatar
NO.. Tune it before break in!!!!!
Old Apr 20, 2011 | 05:55 PM
sh!ft's Avatar
two completely different responses, one good one, and one how the hell did you come up with that theroy response.
Old Apr 20, 2011 | 06:12 PM
SovXietday's Avatar
Exactly. Boost will seat your rings rather well.
Old Apr 20, 2011 | 10:25 PM
W!d3b0dYr3X's Avatar
the guy who replied to tune before breaking it in prob meant to say that becuz if u r running rich u run the risk of washing the cylinder walls down with fuel and washing the protective oil film away as the piston rings seat which will lead to lower compression as the cylinders will loose the cross hatch. u should always tune before breaking in the motor and then preferably break the motor in on the dyno if at all possible.
jdm.fanatic
Jan 10, 2009 01:14 PM
magicguy
Apr 14, 2007 03:52 PM
adictionbass
May 4, 2006 07:39 AM
NVturbo
Mar 16, 2005 05:33 PM
crx1856
Oct 25, 2003 04:34 PM
