when it's time to upgrade the wastegate?
Old Mar 25, 2003 | 11:04 AM
austrian type-R's Avatar
Default when it's time to upgrade the wastegate?
Is the limit measured by hp, exhaust diameter or boost level? What is the limit of a 35mm wg?
I want to take down my meng manifold for porting out the damn wg flanch there to bring the boost down (cause I get 1 Bar with .045 Bar spring, thats the way to go according to tony1, thanks) and to take down the turbo too for turning it 180 degrees to get the compressor housing from the passenger side to the driver side....need to run the 3inch dp streight from the hot side housing out and down to the exhaust without making stupid turns like on the driver side where the a/c compressor is. Also I want to relocate the air filter to the driver side and mount it about 10inch above the road to suck in more fresh air, will mount some carbon heat shields and water shields of course.
And since I want to do that major work, I think about upgrading my Tial 35mm to a 40mm wg, cause since the manifold is off from the engine I can easy weld the 4bolt flanch (which is needed for the 40mm wg) to the header. Don't need to overbore the 35mm wg flanch then
What would you do?
....and since the turbo is off, I should upgrade that part too.... ...damn, it never has an end.
Old Mar 25, 2003 | 12:33 PM
DD_JonnyLee's Avatar
Default Re: when it's time to upgrade the wastegate? (austrian type-R)
ttt for ya
Old Mar 25, 2003 | 01:52 PM
accordfreak's Avatar
Default Re: when it's time to upgrade the wastegate? (TrboGSR)
hey i'm just wondering, did you brace your meng manifold?
Old Mar 25, 2003 | 10:51 PM
Default Re: when it's time to upgrade the wastegate? (accordfreak)
no, my meng manifold is still good.
Old Mar 25, 2003 | 11:20 PM
shortyz's Avatar
i sometimes wonder because old porsches used 30 mm's and they were running 14.5 psi of boost.
i think wastegate placement is the big issue
90Rexx
Dec 8, 2009 03:42 PM
crxnj
Jun 10, 2005 05:28 PM
KStuned
Dec 8, 2003 11:52 PM
bumpin_bass
Jul 15, 2003 03:57 PM
austrian type-R
Mar 25, 2003 10:59 AM
