whats the max hp on a 440cc injector *searched*
B A N N E D
Location: Orange County / Palm Springs 714/76hoe, ca, usa
like the title says i search didnt find it
my goal for my lsvtec is 350hp duable on a 440cc ?what cycle would the 440cc be?
thanks for he input
thanks for he input
B A N N E D
Re: whats the max hp on a 440cc injector *searched* (spoon95eg)
pls just wanna know so i can decide if i should get a higher inj.,thanks
i think they max out just right at 300....if u havent bought injectors yet, get some 750cc since they are all about the same price nowadays
I made 370whp 280ftlbs @ 11psi w/ my CRVtec w/ 440's
Walbro255
Base Rail PSI : 90psi
Final Rail PSI : 101psi
Duty Cycle: 95%
AFR tune: 11.8:1
440's @ 80% duty cycle @ 43.5psi BASE psi is good for : 220-235whp
440's @ 80% duty cycle @ 60psi BASE psi is good for : 255-280whp
Keep in mind that your fuel pressure regulator is a 1:1 so depending on boost pressure your Base pressure will incease.
Example, Base is 43.5psi and your running 12psi of boost. Your now runnin about 55.5psi of rail pressure. Same thing w./ 60psi base would end up being 72psi, total.
I wouldnt go for 440's, The 550's could keep a decent duty cycle but at a higher rail pressure. Wich can be a good thing if not too high or a bad thing if "too" high.
The higher your fuel pressure the cleaner your combustion and more complete it will become. You'll notice better gas milage, less soot build up and possible to make a more efficent motor all round. I personaly think the most rail pressure you want to see is 120psi as a final PSI. This means keeping your base at a 90psi should be plenty to keep your final at or below 120psi.
If you try to run "too much" pressure you can wear your pump out quick and/or cause the fuel to cavitate. This can cause the fuel to seperate and cause gas bubbles to form, causing sudden pressure drops in the rail and fuel starvation.
I personaly ran a pump for 2 1/2 years on a base of 80psi running 20-25psi daily with no problems with pump failure or fuel cavitating.
Walbro255
Duty Cycle: 95%
AFR tune: 11.8:1
now your talking about an adjustable fuel pressure reg right? Because the stock one as we all know is not. Im just trying to get this straight because Im in the same boat.
Re: (B18C Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C Turbo »</TD></TR><TR><TD CLASS="quote">now your talking about an adjustable fuel pressure reg right? Because the stock one as we all know is not. Im just trying to get this straight because Im in the same boat.</TD></TR></TABLE>
your stock regulator is a 1:1. The factory regulator also increase fuel pressure in proportion to the boost pressure increase. If you are running 16.5psi of boost pressure, the fuel pressure will rise to 60psi to maintain the same differential fuel pressure of 43.5psi (60.0-16.5=43.5). But yes, your factory regulator works as a 1:1 and will increase return line resistance as boost levels increase.
B A N N E D
Re: (JDMs1eeper)
Btw I already have the 440cc inj that's why I ask cuz I don't want to buy another injector again so how about if my goal is around 330 hp so that mean my 440cc is ok as long as I have a aftermarket fpr or what ?
Thanks a lot for all the input
Just to muddy the waters, I use 440's on my hondav6, dyno'd at 464whp. I have 60 psi fuel pressure wot at 10 lbs boost, the duty cycle is about 65%. Walbro in the tank, aeromotive 1:1 reg. I'd listen to these guys though as they know the ropes on the 4bangers and what works best.
Re: whats the max hp on a 440cc injector *searched* (elevatedj32)
yup, you have 440's but you also have 2 extra 440cc injectors to support your power.
a 440cc 4 cylinder has a total of 1760cc's to support x amount of power
a 440cc 6 cylinder has a total of 2640cc's to support x amount of power
Re: whats the max hp on a 440cc injector *searched* (JDMs1eeper)
Sell the 440's and get at least 550cc injectors (if not bigger) and buy a Walbro 255 and your good to go. With the base fuel pressure at 42psi you will get about 300whp or a little more out of the 440cc injectors, but they will be completely maxed out.
Re: whats the max hp on a 440cc injector *searched* (scB20teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scB20teg »</TD></TR><TR><TD CLASS="quote">Sell the 440's and get at least 550cc injectors (if not bigger) and buy a Walbro 255 and your good to go. With the base fuel pressure at 42psi you will get about 300whp or a little more out of the 440cc injectors, but they will be completely maxed out.</TD></TR></TABLE>
x2
x2
Leaving room for upgrade is always a good idea and the 440-750cc RC injectors are all about the same price anyways.
https://honda-tech.com/zerothread?id=1419494
Best prices around, let Phil hook you up with a nice set for a great price
Re: (spoon95eg)
It's really not worth blowing your engine for to save $300. Just get some 750's. If you want to take the maxxed out 440cc/min route then enjoy, but I hope you have a backup swap.
B A N N E D
Re: (KeyserSoze)
Hahaha oh well I guess I need to buy a bigger injector
Anyone wanna trade plus cash on my part lmk lol
Thanks for all the input peepz
Re: (turbosnatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosnatch »</TD></TR><TR><TD CLASS="quote">http://www.rceng.com/technical.htm </TD></TR></TABLE>
this link is posted like once a day on here. i bet half the hits are referenced from honda-tech
platinum
platinum
Re: whats the max hp on a 440cc injector *searched* (eg crunkmonster)
you can go as big as you want its just the duty cycle you run them at so i would just go with 1600cc because at least you wont have to buy injectors for a while
injector experts please enter-injectors sizing for HP goals and fuel pressure and how they are relat
BlueShadow
12-09-2005 11:11 AM
