what's an ecu do?
Old Nov 13, 2002 | 07:11 PM
asianspeed's Avatar
Default what's an ecu do?
Ok, this is a new subject for me...I don't know much about ecu's at all. Can someone explain the benefits for running certain ecu's and what goes into the conversion.
I've got a 99 ls ecu and I'm going turbo soon, I'm wondering, is there a better ecu that I should look into? Oh yeah, I'm not going to be running hondata.
If anyone can shed some light on the subject or show me where I can read up on some information that would be great.
Thanks
Old Nov 13, 2002 | 07:16 PM
LsTurbo91's Avatar
Default Re: what's an ecu do? (asianspeed)
http://www.hondata.com
Old Nov 13, 2002 | 07:20 PM
b16ahybrid's Avatar
the ecu controls the engine.
Generally you should stick with the ecu that goes with the engine, but in some cases it's cheaper to use an ecu from another car.Like in my case it was cheaper to buy a 93 gs-r ecu then a 94-95 del sol vtec.
Sometimes when people do swaps (like from a d16 to a b18) they will use the stock civic (p-28) ecu ut just reprogram it because it's cheaper.
what engine do you have?
Old Nov 13, 2002 | 08:28 PM
asianspeed's Avatar
Default Re: what's an ecu do? (b16ahybrid)
I have the orginal engine, b18b. But I read posts before that said that older ecu's (obd0 & obd1) are more performance oriented and the obd2 (mine) is more economic/emissions oriented. Would it be better to change? If so, what and why?
titan74
Mar 14, 2013 01:17 AM
detour94civic
Dec 27, 2010 02:55 PM
mawkiemarc
22
Feb 28, 2006 12:21 AM
-=ELF=-
Mar 2, 2002 05:07 PM
