Clutch swap without an alignment tool??
Old Aug 18, 2002 | 09:08 PM
TurBoXBirD16's Avatar
Default Clutch swap without an alignment tool??
is it easy to use a finger??
what else can i use??
do u guys know if i can find them in canadiantire or partsource??
thanks
Old Aug 18, 2002 | 09:11 PM
Loco Honkey's Avatar
Default Re: Clutch swap without an alignment tool?? (xbird)
I've done 15- 20 or so clutch jobs, and have never used a tool... I take my time and line them up by eye, and all have been successful.
Old Aug 18, 2002 | 09:48 PM
PrecisionH23a's Avatar
Default Re: Clutch swap without an alignment tool?? (F=WT)
ive never done one without the tool nor have experience with eyeing it up so i cant really knock that technique, however i feel safer using the tool. usually if you buy the kit it will come with a tool... or you can tell the shop to send you one wiht the clutch kit
[Modified by GudeH23a, 1:48 AM 8/19/2002]
Old Aug 18, 2002 | 10:01 PM
Ri5e's Avatar
Default Re: Clutch swap without an alignment tool?? (GudeH23a)
what you can do is, use a socket with a diameter that is smaller then the diameter of the clutch spline. Stick it in, then rotate it around and just eyeball it so that its center.
Old Aug 18, 2002 | 10:15 PM
boostaholic's Avatar
Default Re: Clutch swap without an alignment tool?? (BG Boost)
Broom stick
Old Aug 19, 2002 | 02:11 AM
blufke's Avatar
Default Re: Clutch swap without an alignment tool?? (boostaholic)
we "eyeballed" it for my friends rex and it worked just fine. we used a tool with mine cuz the clutch kit came with one, that was easier and didnt have to worry about it at all. a local auto store should carry one.
Old Aug 19, 2002 | 02:24 AM
ninesecrx's Avatar
Default Re: Clutch swap without an alignment tool?? (blufke)
get it semi tight and then put the trans in, and they you can just rotate the crank and tighten the pp bolts one at a time as they come to were the starter hole is.
Old Aug 19, 2002 | 02:28 AM
Spankee2K's Avatar
Default Re: Clutch swap without an alignment tool?? (ninesecrx)
get a tool...its like 2 bucks
Old Aug 19, 2002 | 05:53 AM
AGen2integra's Avatar
Broom stick
done that one before
Old Aug 19, 2002 | 07:01 AM
spectunedphil's Avatar
Default Re: Clutch swap without an alignment tool?? (AGen2integra)
how hard is a clutch to install.....do you need more than one person to install..what tools do need.can you do it on jackstands....any information would be helpful..thanks
Old Nov 11, 2002 | 10:18 PM
accordfreak's Avatar
Default Re: Clutch swap without an alignment tool?? (hondadriven)
wondering also
Old Nov 11, 2002 | 10:22 PM
CzanSOHC's Avatar
Default Re: Clutch swap without an alignment tool?? (accordfreak)
it's not that hard to do. me and my friend just did it this weekend, we fucked up a ball joint so we are still trying to fix that. but it;s not that hard, have an extra jack to help drop the tranny, or use a engine lift to "suspend" the tranny, earier to line up.
Old Nov 13, 2002 | 02:34 PM
Smashback's Avatar
Default Re: Clutch swap without an alignment tool?? (CzanSOHC)
I just pulled my tranny for the second time in a year....this time rather than messing with a jack I just pulled it off the engine and out the top of the engine bay. Thing only weighs like 70 lbs.
Old Nov 13, 2002 | 04:00 PM
ninesecrx's Avatar
Default Re: Clutch swap without an alignment tool?? (Hatchblack)
Tuff guy eh I lost my weight set, so I just use the b-series cable tranys to do my curls. Gotta stay swull.
single cam tranys weigh 70 pounds
B-series tranys weigh 90 pounds...
[Modified by ninesecrx, 1:05 AM 11/14/2002]
Old Nov 13, 2002 | 07:06 PM
GraphiteAccord's Avatar
what does a H series tranny weight?
Old Nov 13, 2002 | 08:09 PM
ninesecrx's Avatar
Default Re: Clutch swap without an alignment tool?? (GraphiteAccord)
I have never weighed a H series trany, maybe someone else knows?
Old Nov 13, 2002 | 08:12 PM
Smashback's Avatar
Probably a lot more...but I have an SOHC so that was a damn good guess!
Old Nov 13, 2002 | 08:31 PM
paulzy's Avatar
that's funny...the tranny looks like it's physically too big and is impossible to pull it form the top with teh engine still mounted
tacchan
26
Mar 17, 2010 11:25 AM
badpootie
19
Jun 20, 2005 09:47 AM
RTW DC2R
Feb 11, 2005 04:37 PM
DubyaAye
May 21, 2004 10:53 PM
darkstarsi
Feb 26, 2002 05:52 PM
