what's best for FI...
Old Jul 24, 2003 | 09:49 PM
_Endless_'s Avatar
Default what's best for FI...
stock spec valve clearance or tighter than stock valve clearance?
i heard that tighter valve adjustment will result in increase air flow but too tight will wear out the valve/valve components.
so which is better or does it matter? will there be any significant gains?
Old Jul 24, 2003 | 10:31 PM
falcongsr's Avatar
What is this crap?
Default Re: what's best for FI... (_Endless_)
the "tighter" the clearances, the further the cam can push the valve down into the cylinder, so you do breathe a littel better. with a turbo you're pushing so much volume into the cylinder i dont think its as big a deal than with a NA motor, which is trying to suck as much air as possible out of the atmosphere.
i wouldnt run them tighter than the spec. theres no real reason to do it in my opinion. its probly ok to run them a little tight but within spec...but i wouldnt see why.
Old Jul 25, 2003 | 10:59 PM
_Endless_'s Avatar
Default Re: what's best for FI... (NOT EVIL falconGSR)
ok thanks.
any more comments?
sslude
Jan 26, 2003 07:21 PM
Ri5e
Aug 9, 2002 07:48 AM
