Whats the best???
Old Sep 5, 2003 | 02:55 PM
  #26
PrecisionH23a's Avatar
Default Re: (SpoolnG2)
Custom 88mm CP 9.0:1 pistons with swain tech top gold coat and pc9 side skirt coat.
CP is the piston of my choice as well, and yes those in the picture are the ones I use.
Old Sep 5, 2003 | 04:23 PM
  #27
lazerus's Avatar
Default Re: (GudeH23a)
watch out, yellow makes it faster!
Old Sep 5, 2003 | 04:24 PM
  #28
lazerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">talked to the guy that built my motor, and he said it wasn't detonation, it was that i did to many highway blasts and the pistons got so hot and started to deteriorate he said.</TD></TR></TABLE>
must have run them lean, or inadequate cooling (lack of (or inadequate) piston oil squirters) could be a plausable cause.
Old Sep 5, 2003 | 04:47 PM
  #29
ekb18c's Avatar
Default Re: (igotyofire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote">Cp has so many votes, yet i dont think that many people are using them, reminds me of the thread when everyone picked ef1 cams but nobody except 1-2 people had experience with them</TD></TR></TABLE>
I have used JE and Arias, both with great sucess.
Old Sep 5, 2003 | 05:53 PM
  #30
SpoolnG2's Avatar
Default Re: (ekb18c)
yeah, he said it looked like i ran it lean.
Old Sep 6, 2003 | 12:32 AM
  #31
lazerus's Avatar
pistons will melt if they overheat.
If you boost on the freeway and you overheat your pistons (melt) them, you have inadequate piston cooling, this could be from several different things, but mainly its from detonation and running lean, either one of theese two things quickly destroys even the most expensive pistons, and their coatings.
pistons can also overheat due to the thermal stresses placed on them, and insufficient cooling.
Most factory FI motors will have a very good piston squirter setup for cooling and lubrication.
That is one reason that the 2jz pistons can withstand 900+ WHP without letting go. Aside from the fact that they are hypertuectic (from what i have seen)
Old Sep 6, 2003 | 08:13 AM
  #32
SpoolnG2's Avatar
Default Re: (lazerus)
what is the best way for me to cool my motor? cooler thermostat? water weter? how about c & r civc radiator? will all that help me out? also, is there anything else i can do?
Old Sep 6, 2003 | 09:43 AM
  #33
bottlefedb18c1's Avatar
what about an oil cooler if you cool the oil that is hitting the bottom of the piston it should cool it the best
Old Sep 6, 2003 | 11:50 AM
  #34
TurboRBoostedS2G's Avatar
Default Re: (bottlefedb18c1)
what are peoples thoughts on ROSS pistons???
Old Sep 6, 2003 | 09:24 PM
  #35
SpoolnG2's Avatar
Default Re: (TurboRBoostedS2G)
someone earlier in my post said he had a lot of noise from them. other then that, i don't know anyone that uses them. sorry
Old Sep 6, 2003 | 11:01 PM
  #36
TurboCX's Avatar
Default Re: Whats the best??? (boosted hybrid)
All the pistons that you posted will work just fine. I would go with 9:1 compression pistons.
kenny7231
Jan 7, 2008 05:27 AM
calib17a
Jun 3, 2004 12:23 PM
EVOCELICA
Feb 11, 2003 07:19 PM
TheSwift1
Sep 25, 2002 05:03 PM
