What is your timing under boost?? GSR Turbo?
Just trying to figure out this problem of mine
(see this) https://honda-tech.com/zerothread?id=327295
Talking to a local honda turbo guy (maddskilz), he hooked my car up to his scanner and took it on a spin,
While under boost, it's around 15 to 20 degrees
Is that right? Also, where exactly is the knock sensor on this damn car? Can't seem to find it
TIA
TIA
Re: What is your timing under boost?? GSR Turbo? (slwazgsr)
mine is usually in the low 20's-about 21-23.the knock sensor is on the back of the block near the oil filter but not the on right next to the filter.
Mine is low, around 12-14 degrees since i run 14lbs daily on a 60-1 t3. More torque, reliability and quicker spool up with retarded ignition. Let the turbo make the power, not the engine.
Re: What is your timing under boost?? GSR Turbo? (hybrid901)
so that means I'm about right, hmmmmmm, I have no idea what the hell is wrong with my car
Would that knock out the possibility that my knock sensor is bad?
teg19921994
02-05-2018 09:30 AM
